w203 Mecedes Misfire
  • Caritech
  • Caritech's Avatar Topic Author
8 years 9 months ago #15984 by Caritech
w203 Mecedes Misfire was created by Caritech
Hello all. I'm working on a W203 C200 Mercedes with a 1.8L I4 engine that begins to misfire on warm-up.
All coils and plugs were swapped previously by mechanic.
Misfire for all cylinders and O2 B1S2 heater circuit codes were in memory. I cleared them but only the O2 code returned and engine still running rough..
STFT is stuck @ 0.0 and LTFT @ 14.1. Car seems not to want to go into closed loop and STFT won't respond to lean condition (brake booster line pulled) or rich condition (adding throttle cleaner). Engine runs smoother with fuel added
Lambda is 1.3-1.4 at idle
  • Caritech
8 years 9 months ago #16089 by Caritech
Replied by Caritech on topic w203 Mecedes Misfire
I discovered that when the car is running badly it won't enter closed loop, STFT stays 0.0, LTFT 14.1 and B1S1 o2 is 2.3 +/- 0.1. The car runs just fine when the B1S1 is @ 1.5 (normal fluctuations). It'll enter closed loop, fuel trim will adjust LTFT is fixed @ 14.1 and STFT was high pointing me to find the broken vac brake booster line fitting causing lean condition.
Anyone ever met this issue with a car not going into closed loop intermittently? I'm thinking Upstream o2 going crazy or bad ECM.
8 years 9 months ago #16094 by Paul 1949
Replied by Paul 1949 on topic w203 Mecedes Misfire
Not one I,be seen myself but I believe there is a breather pipe under the intake that splits causing weak fuelling
  • Caritech
8 years 9 months ago #16114 by Caritech
Would the vac leak cause the PCM to be stuck in open loop? I never saw that happen. One minute it enters closed loop and STFT works normally and the next STFT is 0.0 and open loop seems stuck.
Time to create page: 0.248 seconds
