Honda Civic D15b no start[Solved]
  • Caritech
  • Caritech's Avatar Topic Author
8 years 10 months ago - 8 years 9 months ago #15706 by Caritech
Honda Civic D15b no start[Solved] was created by Caritech
Hello all. A Honda Civic with a D15b engine hasn't started for 3 weeks. I have a few days to repair as usual.
-Spark is good (Igniter and coil replaced in distributor by mechanic)
-Injector pulse is present
-5v ref good
-Engine keeps flooding (plugs wet after crank)
-Oil smells like gas
-On clear flood mode it tries to start
-Mechanic reported timing and compression good
-Vehicle had no prior issue. It was parked on day and the other no start.
Last edit: 8 years 9 months ago by Caritech.
8 years 10 months ago #15707 by Tyler
Replied by Tyler on topic Honda Civic D15b no start
How's the spark plug condition, sir? I see that the igniter and coil have been changed, but are you still getting strong spark at the plugs?
8 years 10 months ago #15708 by Chad
Replied by Chad on topic Honda Civic D15b no start
What is your fuel pressure? Does it hold? If you disable the fuel pump, will it fire off of Starting fluid?
  • Caritech
8 years 10 months ago #15710 by Caritech
Replied by Caritech on topic Honda Civic D15b no start
The plugs have decent spark. I didn't check fuel pressure yet and no it didn't start off fluid with pump off. One thing the customer mentioned is the main relay was inoperative and he soldered everything up and it started back working car still didn't start.
8 years 10 months ago - 8 years 10 months ago #15711 by Chad
Good spark at the spark plugs. Check. Fuel. Check.
How's compression?
When Cranking, how does it sound?
Last edit: 8 years 10 months ago by Chad.
8 years 10 months ago #15713 by johnphufnagel
Replied by johnphufnagel on topic Honda Civic D15b no start
Check fuel pressure and drop also check currant to fuel injectors maybe bad injectors stuck open, see if you have pintle bump if you have a scope
Experience doesn't cost it pays
  • Caritech
8 years 10 months ago #15714 by Caritech
Will check all those things when I get back to the shop. Thank you.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
8 years 10 months ago #15716 by cheryl hartkorn
Replied by cheryl hartkorn on topic Honda Civic D15b no start
what year is this honda? does it have an egr valve that is stuck open? or a stuck closed idle air control since it tried to start with the gas pedl down... how ws the timing checked?? when people tell me they check things ill check myself.. not saying hes lying saying it might not of been checked right
  • cheryl hartkorn
8 years 10 months ago #15717 by cheryl hartkorn
also what does the engine coolant temp sensor read
8 years 10 months ago #15721 by fudgie
Replied by fudgie on topic Honda Civic D15b no start
Cam timing?
  • Caritech
8 years 10 months ago #15749 by Caritech
Got to the shop late after the day job.
Fuel pressure was checked at the tank and showed a slight leak down.
No difference with ECT sensor unplugged.
Compression was 150 with throttle closed, cyl. 1.
No egr.
I was told mechanical timing was checked and was off but was "corrected."
Circumstances caused me lock off early but I have been thinking about something. The distributor has CKP, CYL and TDC pickups. Could it be possible for one of these to throw off ignition timing? An entire distributor couldn't be sourced so they changed igniter and coil because they reported no spark but when I got it on the site visit it had spark. The rest of the distributor was never changed. Will be getting a timing light tomorrow.
  • Caritech
8 years 9 months ago #16090 by Caritech
Update: Timing was off, belt was loose and a final compression check showed 40'ish psi across the board. Swapped a long block and Vtec kicking in again yow.
