Need Help! - low reading on downstream 02 sensor - 07 dodge ram 1500 -
- jb13
It is now clear to me that there is a communication problem with the pigtail that connects to this sensor. There is either a problem with the computer on the truck with this sensor (which seems unlikely to me since all of the other three sensors work) or there is a problem with one of the wires going from the computer to the pigtail. It does not appear to have any cuts or burns in the wires as far as I can see.
I am not sure what I need to do next.....I do not know where/how to test the wires or see where the ground is for the pigtail. I have tried to find more information but have had no luck. I do not want to take it to the dealer and pay a lot of money to just have them look at it....they will probably assume its a bad computer and charge a lot of money to replace it..
Some help in the right direction would be great! Thanks so much!
- Dylan
- Belgium, Europe
- Thank you received: 327
I'm moving your thread to the repair section
- jb13
- Ben
- Thank you received: 215
- cheryl hartkorn
- Thank you received: 130
- jb13
I do have a multi meter but it is a weird angle to try and test the pigtail. I will give it another shot with the multimeter. I will be posting a video in the next couple of hours with what my scanner is reading on all four sensors. Thanks!
- jb13
- jb13
Cheryl was asking about exhaust leaks, and I'm wondering the same. To me, the sensor is behaving like there's a genuine excess of oxygen in the exhaust, so I'm wondering where that may be coming from.
- jb13
Sorry I forgot to answer that question.....I also read that an exhaust leak could be causing the p0430 code so that is also a possibility.....I guess I just assumed that since the sensor was not reading right and it has a new converter on it that the sensor is the last possible option......would the exhaust leak have to be around that downstream o2 sensor then? Just from a general look down there I have no seen anything but it could be so small that I wouldn't be visible....
Will be uploading the next video shortly! Thanks guys
- jb13
heres the next video
- jb13
here is the video of that you requested....I took it into the shop today and they said there is a small leak right behind the converter! I am having it fixed tomorrow so I am hoping that the leak will solve the problem with the sensor acting up. I'm also praying that the sensor is somehow causing that p0430 code and that there is nothing else wrong with the exhaust.....I can not see how the sensor could cause a converter inefficient code (especially since they have trouble codes for 02 sensors) but I could be completely wrong on it. I will let you guys know tomorrow if the repair solves all of my problems. I plan on getting it fixed and then taking it for a drive around town and then on the interstate
- jb13
If you want to prove out a connection issue, there are a couple options. One would be to use the 5V bias on the signal wire like Cheryl mentioned. The scanner won't show it due to OBDII standards, but those sensors start out at 5V cold, and get pulled down to 0-1V with heater operation. You can measure for this with DMM, and further check the O2 signal ground by shorting the signal TO the ground. If you see the bias go to zero, then you know the ground is OK.
The other would be to disconnect the PCM and load the O2 wires with some kind of light bulb, or even an incandescent test light. It's work, but it'll eliminate all doubt about the wiring.
- jb13
here is a freeze frame of what my scanner shows when the check engine light came on.....if someone could let me know if something is off that could lead me in another direction that would be great.....
if not, then i will start trying to test the connections and see if I can find the problem with wiring..
This video expands on the 5V bias system, if you're interested:
Also, this is the wiring diagram for both downstream O2 sensors:
I went back to the first video that you posted, with all four O2's during startup, and I gotta say... I don't see an O2 performance issue.
- jb13
I'm going to look into the wiring tomorrow and see if it helps my problem.
