02 Grand Cherokee 4.7 engine with no comm and antitheft light on
- chris.arriazola
- Thank you received: 2
8 years 10 months ago #15564
by chris.arriazola
02 Grand Cherokee 4.7 engine with no comm and antitheft light on was created by chris.arriazola
Hello I’m having trouble understanding how this system works. I have a crank but no start on this 2002 grand Cherokee with 4.7 engine noticed the antitheft light is on and I have a no comm on PCM. I’m trying to understand if I need to attack the PCM problem first because it might have something to do with the theft system. I have already checked both my 5v reference circuits and they seem to be fine. My ASD relay is not being commanded to give power to my coils. Would like a little help if possible
- Ben
- Thank you received: 215
8 years 10 months ago #15572
by Ben
Replied by Ben on topic Re:02 Grand Cherokee 4.7 engine with no comm and antitheft light on
Can you communicate with other modules? Do the 12v power points/cigar lighters work?
- chris.arriazola
8 years 10 months ago #15574
by chris.arriazola
Replied by chris.arriazola on topic Re:02 Grand Cherokee 4.7 engine with no comm and antitheft light on
Yes I have communication with everything else but the PCM
- chris.arriazola
8 years 10 months ago #15575
by chris.arriazola
Yes I have power supply and communication with everything else
8 years 10 months ago #15579
Replied by Chad on topic Re:02 Grand Cherokee 4.7 engine with no comm and antitheft light on
With the key on, do you have battery voltage on FUSE 12 (10 amp) -Junction Block behind left side of dash ?
AND
Fuse 6 (30 amp) -Power Distribution Center At right, front corner of eng compartment, next to battery?
AND
- chris.arriazola
8 years 10 months ago #15588
by chris.arriazola
Let me check on these fuses to make sure I’m not overlooking something
