Volumetric Efficiency
  • naros812000
  • naros812000's Avatar Topic Author
8 years 10 months ago #15545 by naros812000
Volumetric Efficiency was created by naros812000
Dears,
I have been diagnosing BMW E70 2007 3.0 si. I need to know if this engine has good efficiency or not.
Here are some data for this purpose
WOT with vehicle stopped.
Calculated Load Value Max 82% Min 2.4
Absolute Load Value Max 48.6% Min 12.5
Airflow rate from MAF 35.65 g/s
Lambda Bank1 sensor1 0.85
Lambda Bank2 sensor1 0.84
for my understanding, this car has partially plugged exhaust coz calculated load isnt high enough to be over 85% and absolute load (intake pressure) is some what high 48.6% and maf is low. The engine is rich.
Is my diagnosis right?
Thanks for any clarification or comments
8 years 10 months ago #15562 by Ben
Replied by Ben on topic Re:Volumetric Efficiency
What is maf reading at warm idle?
8 years 10 months ago - 8 years 10 months ago #15598 by juergen.scholl
Replied by juergen.scholl on topic Volumetric Efficiency
Preferably do a road test. With the car not moving there might be rev limiting taking place, the throttle plate not opening complety etc....
Drive the vehicle while recording the related pids with a scan tool and afterwards input the collected data into a VE calculator - done!
Last edit: 8 years 10 months ago by juergen.scholl.
8 years 10 months ago #15623 by Tyler
Replied by Tyler on topic Volumetric Efficiency
Agree with Juergen, you'll need to go on a test drive to see the readings you want. A throttle snap while stopped won't cut it. :-(
The following user(s) said Thank You: naros812000
