Engine load
  • naros812000
  • naros812000's Avatar Topic Author
8 years 10 months ago #15467 by naros812000
Engine load was created by naros812000
Dears,
Are Engine load, Calculated load and evaluated load the same?
because I want to diagnose BMW X5 E70 and I cant find Engine load in the data. What I see only calculated load and evaluated load.
Thank you all
8 years 10 months ago #15474 by Tyler
Replied by Tyler on topic Engine load
Moved this to Repair, FYI.
I'm not positive what Evaluated Load is, but I wonder if it's the same as Absolute Load? :huh: They're not exactly the same, as Calculated is usually based on the MAF sensor, while Absolute is usually based on the MAP sensor. Absolute is useful for forced induction engines, where volumetric efficiency is expected to be over 100%. I did some experimenting with Calculated and Absolute here:
www.scannerdanner.com/forum/diagnostic-t...ad.html?limitstart=0
  • naros812000
8 years 10 months ago #15485 by naros812000
Replied by naros812000 on topic Engine load
to my understanding, engine load equals absolute load. Am I right?
I want to diagnose how much air is sucked into engine at wot but my scanner doesnt show engine load. Can I use absolute load to help me for this diagnosis with O2 sensor if I want to find out cause of Low Power complaint?
The car doesnt have MAP it has only MAF sensor.
thank you
