PO171 and PO174
  • Deryck
  • Deryck's Avatar Topic Author
8 years 10 months ago #15368 by Deryck
PO171 and PO174 was created by Deryck
Owner of a Jaguar S-type, petrol-engine, year 2002. 3 litre.
The engine malfunction warning light (yellow) infomring me that performance is compromised frequently appears, especially when travelling over 110 m/h.
Checked all hoses and tubes and replaced all sensors.
The problem will not go away.
Any suggestions?
8 years 10 months ago #15420 by Tyler
Replied by Tyler on topic PO171 and PO174
Do you have access to scan data? That'd be the place to start, as we could look at fuel trim data to see when the engine is running lean.
The fact that the light comes on at speed would tend to suggest a fuel issue, either with the MAF or fuel pressure. But, the trims will tell us if that's true or not.
The following user(s) said Thank You: Deryck
8 years 10 months ago #15424 by robert.lesaca
Replied by robert.lesaca on topic PO171 and PO174
in absence of scanner, perhaps basic ocular inspection for loose wire connectors at sensors like MAF, EGR etc.
  • graywave
  • graywave's Avatar
8 years 10 months ago #15425 by graywave
Replied by graywave on topic PO171 and PO174
Also check for vacuum leaks and possible loose or cracked intake hose from air filter
  • Deryck
8 years 10 months ago #15468 by Deryck
Replied by Deryck on topic PO171 and PO174
Dear Tyler
Very grateful for your suggestions. I expect an engine data scanner to be delivered to me some time next week.
Hopefully this will identify the problem.
Thanks again
Deryck
  • Deryck
8 years 10 months ago #15469 by Deryck
Dear Robert,
Many thanks for your suggestion.
Just read your post today and I (or my mechanic) will start checking Monday
Again many thanks
Deryck
  • Deryck
8 years 10 months ago #15471 by Deryck
Dear Graywave,
Thank you for your suggestion. I've looked at leaks before. Will search again.
Again many thanks
Deryck
