no comm. with the scanner and all of the module.(DLC fuse & ground checked)
- Evanlip
8 years 10 months ago #15315
by Evanlip
no comm. with the scanner and all of the module.(DLC fuse & ground checked) was created by Evanlip
hi,there,i didn't mention the car model at my topic because i have 2 cars having the same issue at the same time.
first car is Volvo S40 :
i did diagnose the car few months ago with the same scanner everthing's good,but today the car came back in to check the MIL again,but was not able to communicate with all the system module. my first check was the fuse and ground at the DLC connector,looks normal.i thought it was my scanner problem so i got another one from my friend but still not working.
second car is Ssang Yong Stavic 2.0 Diesel :
the car came in because of the Engine Check Light & SRS Check Light,but i couldn't communicate with PCM and SRS as well,but i could communicate with the TCM,ABS,etc.(if the power and ground of DLC Connector issue,i could no way communicate with the rest modules).
the car runs fine,no startability issue or what so ever.
this is really a tough one to me,spend the whole day checking the car inside out,but nothing was found and do not know what to do next.
not sure if you guys have any similar experience with these.
thanks guys.
thanks guys.
- derekoliveira
8 years 10 months ago #15328
by derekoliveira
Replied by derekoliveira on topic no comm. with the scanner and all of the module.(DLC fuse & ground checked)
Hi, maybe a broken wire between ECM/SRS and DLC, if they use the same pin on the DLC!? Get a diagram to check!!!
8 years 10 months ago #15334
Replied by Tyler on topic no comm. with the scanner and all of the module.(DLC fuse & ground checked)
For our info, what year is the S40? That'll allow me to look up a network diagram, and see how the scanner talks to the ECM.
About your Ssang Yong... I'm not going to be able to find a diagram on that one. :blink: Do you have access to a repair manual? Something that'll show how the DLC is wired to the other modules on the car.
- Evanlip
8 years 10 months ago #15336
by Evanlip
Replied by Evanlip on topic no comm. with the scanner and all of the module.(DLC fuse & ground checked)
hi,Tyler,the Volvo is a 2003 model with 1.9L 4cyl Turbo 5A engine.
regarding the Ssang Yong,i will try to get the repair manual.it's kinda hard to get a repair manual here in my country,i bought most of the manual online but its europe spec,but i use them for a reference.
- Thank you received: 1138
8 years 10 months ago #15358
Replied by Noah on topic no comm. with the scanner and all of the module.(DLC fuse & ground checked)
Maybe worth mentioning, check the pins on your scanner connector.
I have been letting people borrow mine and ended up with a bent pin that resulted in hit or miss communication problems...
- Evanlip
8 years 10 months ago #15361
by Evanlip
hi,Noah,thanks for the tips,i have checked those pins after reading your message,those are in good shape.
what else i can check?
8 years 10 months ago - 8 years 10 months ago #15362
Replied by Andy.MacFadyen on topic no comm. with the scanner and all of the module.(DLC fuse & ground checked)
I have found sometimes if you fail to connect with one module the scantool won't connect to other modules until you key off and unplug and restart the scantool. The other issue I find is some manufacturers 16 pin sockets don't contact the pins of the scantool plug as well as others especially as the pins on some far eastern made scantool 16 pin plugs are not exactly to spec.
On the Ssang Yon have you tried plain vanilla OBD2 to talk to the PCM ?
Last edit: 8 years 10 months ago by Andy.MacFadyen.
- Evanlip
8 years 10 months ago #15363
by Evanlip
good day,Andy.MacFadyen,appreciate your sharing.
"I have found sometimes if you fail to connect with one module the scantool won't connect to other modules until you key off and unplug and restart the scantool. The other issue I find is some manufacturers 16 pin sockets don't contact the pins of the scantool plug as well as others especially as the pins on some far eastern made scantool 16 pin plugs are not exactly to spec."
i have tried multiple times of key off and reconnecting the scan tool,even tried with the other brand of scanner,still the same.
may i know wat is plain vanilla OBD2?
thank you
thank you
8 years 10 months ago - 8 years 10 months ago #15364
Sometimes trying to connect to a PCM in manufacturer specific mode can be unreliable especially with low volume imports, I keep a very cheap OBD2 bluetooth dongle which always seems to connect.
The Volvo ISTR a Paul made a video on a Volvo with coms problems that turned out to be due to water ingress into module the scuttle/dash area.
----Edit
Found it -- it was a 2006 S80
----Edit
- Evanlip
8 years 10 months ago #15365
by Evanlip
oh gosh,its a premium channel video isn't it?i couldn't view it,its not available in my country.
anyway i could view it?
thank you
thank you
