Low Voltage Output
- nissan956
- cheryl hartkorn
- Thank you received: 130
- cheryl hartkorn
- nissan956
I haven't tried a jumper wire from the battery to the positive lead of the fuel pump. Would that not fry something? Would that be a permanent solution if it worked?
By the way, I do have the factory service manual. The ground circuit checked fine as did the signal (ECM) circuit. But it is the power circuit that is not checking out. Thanks for any suggestions.
Your voltage readings definitely aren't ideal.
Running a jumper like Cheryl suggested would be totally acceptable, as long as you're careful and double check your connections. The danger would be in jumping 12V to the control wire at the fuel pump relay while the relay driver is on. Stick to the load side of the fuel pump circuit, and there's no chance of frying something.
A good place to start would be jumping from the fuel pump relay output, black/red at the relay, to the power wire at the pump. If the voltage drop improves significantly, then you know there's an issue in that wire. If you're concerned about a fuel pressure issue, then this would be the time to watch the gauge and see if the pressure goes into spec with the jumper applied.
- nissan956
So, what if I connect a jumper wire from the battery to the power wire on the fuel pump bypassing any of the intermediate connectors? Would that fry anything or cause the ECM to act funny? I'm including some diagrams. Thanks again.
...A few minutes later I come back and it has hard time starting. The pressure is not there. When I use my Power Probe to power the pump, it works just fine...
So, you can hit the pump with your Power Probe, and get the pressure up to spec? :huh: If that's true, then you've already done the above jumper test. You could try making the jumper semi-permanent just to confirm your theory.
- nissan956
The jumper wire should ideally be as big or bigger than the existing fuel pump wire. If you're still concerned about damaging the PCM, you can remove the relay or fuse while the jumper is in place. That'll isolate the PCM from whatever you're doing with the fuel pump.
- nissan956
IN any case Tyler, wouldn't the jumper wire from the battery be HOT all the time, and thus, the fuel pump would operate even when the car is turned off? Isn't removing the FUSE or RELAY from the PCM make operation of the vehicle impossible? Doesn't the PCM control the fuel pump, injectors, etc. Thanks for the comments.
Also, fuse #3 only feeds the fuel pump relay, so you won't interrupt power to anything else by removing the fuse or relay. Check out this power distribution diagram for more info:
- nissan956
nissan956 wrote: I'm sorry Tyler. I understand your point...kind of..lol.
Sorry man, I'm really not trying to confuse you! :blush:
That Fuel Pump circuit is only hot on RUN or ON when the wiring is the way it is right now. But if I "jump" from the battery that is HOT all the time, wouldn't that make that wire (Black/Red) HOT all the time too. That is what I was worried about.
You're right. If you jump straight from the battery then you'll definitely be hot all the time. I kept going back to that diagram you had drawn up:
Wired this way, getting power from the wire that comes off the ignition switch to the fuse box, then it won't be hot all the time. This lets the ignition switch decide when the pump runs, instead of the fuel pump relay.
From the Fuel Pump circuit schematic the PCM is also powered by the Fuel Pump Relay at connector 8. But I would think that is only there for the priming perhaps, or to simply open the circuit.
Negative, that pin #8 at the PCM isn't a power, just the PCM's control of the fuel pump relay. The PCM will ground that pin for the prime, and once the engine starts turning. That wire is grounded any time the engine is running. This is why I suggested removing the relay as an option - the PCM has no way of determining if the relay is there at all.
So, you stated that I could remove the fuel pump fuse? I thought you mentioned to remove the PCM relay or fuse and run it like that! My fault if I misunderstood. You never suggested that, right, lol? Thanks again Tyler.
If you have a jumper from B+ to the fuel pump power wire, then you can totally run without that fuse or the relay.
- nissan956
- nissan956
