2006 Cadillac DTS with a Y vin. Only one engine that year.
  • coastguardwayne
  • coastguardwayne's Avatar Topic Author
8 years 10 months ago #15202 by coastguardwayne
2006 Cadillac DTS intermittently cranks a while before it lights off. Not often when cold Displaying codes P0134 for O2 sensor P1133 for O2 sensor. P2A00 for O2 sensor. P0340 for Camshaft position sensor. P0341 for Camshaft position sensor. It seems to help if I step on the gas pedal when it cranks a long time, though I know for a fact there is no throttle cable, or accelerator pump, for whatever it is worth. The current camshaft position sensor is less than a year old as well as the bank 1 sensor 1, 02 if thats the rear manifold. Oh and I just put in a new ECU, Throttle body, throttle pedal position sensor plus a new map and maf sensor as well. It then ran like a new car for several weeks and then Bada bing it fails to start like it should. I've done a pretty fair visual look for the unexpected and as a result cleaned up some of my wiring. Note also the Catalytic was changed in the past 6 months. Your thoughts gentlemen?
8 years 10 months ago #15211 by Andy.MacFadyen
I don't know these engines but the cam sensor is one of the most important sensors on an engine, some computers won't start the engine without but some use a fall back strategy and after a few cranks use the crank sensor alone and revert to bank injection rather than fully sequential injection.
As you have codes for multiple sensors could be you have wiring damage or corrosion.
The following user(s) said Thank You: coastguardwayne
