Grand Cherokee ignition timing
  • Jasondo
  • Jasondo's Avatar Topic Author
8 years 10 months ago #15120 by Jasondo
Grand Cherokee ignition timing was created by Jasondo
Ignition timing on cylinder 1 at idle is bouncing around 9 degrees and while driving when I leave a from a stop just touching the throttle it jumps up too 36 or 38 degrees and comes down in degrees the faster I go. That doesn't seem right too me. I would of thought it would start around 9 and go up in degrees the faster you go. I have the 4.0 liter in the grand Cherokee. If the timing isn't working right what should I look at first?
8 years 10 months ago #15185 by Tyler
Replied by Tyler on topic Grand Cherokee ignition timing
Hey Jasondo! I've been looking at some of my old captures, and I'm not sure that you're necessarily looking at a problem. To be honest, I don't look at spark advance all that much on most vehicles, except on some cases of low power. Is there a specific symptom you're experiencing? Or are you just concerned about the spark advance by itself?
What year is your Jeep? For comparison, this is a capture I took off an '02 Grand Cherokee, no issues. There's a couple times where the spark advance goes up to around 30 degrees on initial throttle application.
www.scanshare.io/share/Iynbp_Qx8EKduuTRHGeVIA
Since the MAP and TPS are the primary load inputs on this engine, they're the ones that the PCM will look at for spark timing. For comparision, I also looked at a 4.7L from a 2000 Grand Cherokee, and it has the same kind of spark advance behavior.
www.scanshare.io/share/Jf4XS3bVRk2RD71Ij3K2cw
The following user(s) said Thank You: Noah, Jasondo
