Iod circuit problems
  • Ken.e.wilcox
  • Ken.e.wilcox's Avatar Topic Author
8 years 11 months ago - 8 years 11 months ago #14990 by Ken.e.wilcox
Iod circuit problems was created by Ken.e.wilcox
I have a 2003 dodge ram 1500. 5.7l engine rwd.
I have no communication with the scan tool. Also, interior lighting, radio, door locks/Windows rke do not function when the key is off. They do function with the key one.
At the switches I have 5v ref with key on but not key off
Fuse 51 has power on both sides. Ground at pin 4 and 5 on dlc are good (test light connected to b+) no power on pin 16 ever.
Right now I am leaning towards a bad cluster but need to do more checks.
Anyone else have any idea on direction from here? (I have all data and diagrams available)
Last edit: 8 years 11 months ago by Ken.e.wilcox. Reason: Adding information
8 years 11 months ago #14991 by Chad
Replied by Chad on topic Iod circuit problems
Does the UNDERHOOD LAMP work?
  • Ken.e.wilcox
8 years 11 months ago #14992 by Ken.e.wilcox
Replied by Ken.e.wilcox on topic Iod circuit problems
My truck is not equipped with an underhood lamp.
8 years 11 months ago #14993 by borntoroll
Replied by borntoroll on topic Iod circuit problems
Check if you have a short to ground from pin 16 of the DLC and if not just supply it with 12v through a lightbulb, a 12v 21watt one (it will supply 1.7A at max) or a 55 watt one (4.5 amps maxx) or a fuse. Why do you suspect instrument cluster?
  • Ken.e.wilcox
8 years 11 months ago #14994 by Ken.e.wilcox
Iod Fuse feeds to the cluster 1st then the radio and dlc. No problems with the clusters operation. That's why I suspect it. Maybe a inter 5am short or bad connector.
8 years 11 months ago #14995 by borntoroll
Electricity doesn't work this way. It supplies every module at the same time as diagram is showing.
8 years 11 months ago #14999 by Chad
Ken.e.wilcox wrote: No problems with the clusters operation.
Then, your problem is AFTER splice S204. But, it is not the cluster.
