97 honda accord starts then stalls (FIXED)
  • rod747
  • rod747's Avatar Topic Author
8 years 11 months ago - 8 years 10 months ago #14936 by rod747
Got 97 Honda accord, it starts then stalls then doesn't start again. I replaced the main relay no fix.
Last edit: 8 years 10 months ago by rod747.
8 years 11 months ago #14937 by EricGoodrich
Replied by EricGoodrich on topic 97 honda accord starts then stalls
Ignition, air, fuel, compression, timing. Check those and I'm sure you'll get it fixed.
The following user(s) said Thank You: rod747
8 years 11 months ago #14940 by Chad
Replied by Chad on topic 97 honda accord starts then stalls
How long does it run before it stalls? When it doesn't start, which one of the items that EricGoodrich mentioned are you missing? Start with... Do you have spark? Do you have fuel pressure and injector pulse?
  • rod747
8 years 11 months ago #14949 by rod747
Replied by rod747 on topic 97 honda accord starts then stalls
It runs about 10 seconds and then it stalls. I got a p0141 code. after it stalls the starter signal pid says no while I'm cranking it over. I'll be back tomorrow with more info.
  • rod747
8 years 11 months ago #15045 by rod747
Update it is a blown head gasket
  • rod747
8 years 11 months ago #15046 by rod747
Man it was a blown head gasket. I bet u one thing the first thing I do from now on is check the oil lol. It was almost half way up the dip stick and milky looking.
