GM 3.4L crank sensor glitch?
  • Wadmancpu
  • Wadmancpu's Avatar Topic Author
8 years 11 months ago #14858 by Wadmancpu
GM 3.4L crank sensor glitch? was created by Wadmancpu
This is a wavef orm from the 3x crank sensor on an 01 Grand AM with the 3.4. Appears every fourth spike is different. Look normal?
8 years 11 months ago #14871 by juergen.scholl
Replied by juergen.scholl on topic GM 3.4L crank sensor glitch?
This looks like anormal VRS signal, probbly not every 4th but every 7th spike is different. Your time base is at 100ms total screen, I suppose there is just one crank revolution to be seen. So this accounts for something less than 200 ms for a complete cycle (720 deg.) and then it would be taken while engine idling...
To be sure It will be necessary a picture where the supposed "glitch" is to be seen at least twice within one screen shot.
  • Wadmancpu
8 years 11 months ago #14875 by Wadmancpu
Replied by Wadmancpu on topic GM 3.4L crank sensor glitch?
Ok, what causes the 7th spike to be different? I have a hard starting issue with a misfire at idle.
8 years 11 months ago #14876 by juergen.scholl
The seventh spike is caused by an additional notch in the reluctor. Its function is to identify crankshaft position.
  • Wadmancpu
8 years 11 months ago #14877 by Wadmancpu
Gotcha, thanks for your replies.
