[FIXED] 2003 Hyundai Elantra Timing Belt Walking
- scarney
- Thank you received: 5
8 years 11 months ago - 8 years 10 months ago #14673
by scarney
[FIXED] 2003 Hyundai Elantra Timing Belt Walking was created by scarney
Hi,
I am working on finishing up my first timing belt job on a 2003 Hyundai Elantra. I am having trouble where the belt is walking either towards the engine or away from the engine. Does anyone have any tips, I am really stuck on this one. Best bet is to check out my YouTube video where I explain the problem. www.youtube.com/edit?o=U&video_id=KFzBk840rN4
I can get the belt walk toward or away from the engine, anywhere but right in the middle. If the belt walks towards the engine, it seems to be scrubbing a bit against a flange on the back side of the tensioner. If it walks away from the engine, it seems like it might okay, since it's blocked down beneath by the crankshaft pulley. I really need some help here. Thanks.
Steve
Steve
Last edit: 8 years 10 months ago by scarney.
- Ben
- Thank you received: 215
8 years 11 months ago #14678
by Ben
Replied by Ben on topic Re:2003 Hyundai Elantra Timing Belt Walking
Hey good job on the timing belt your almost done don't worry about it walking to 1 edge or the other they will do that . That's what the lips on the tensioner and crank pulley are for to keep it from walking to far. Go ahead and put it back together make sure everything is tight and properly adjusted(go for the higher end of adjustment on the tensioner so as belt wears it doesn't come out of spec.
8 years 11 months ago #14687
Replied by Chad on topic 2003 Hyundai Elantra Timing Belt Walking
- Ben
8 years 11 months ago #14690
by Ben
If you past the video id in the YouTube search bar it will come up
KFzBk840rN4
KFzBk840rN4
- scarney
8 years 11 months ago #14691
by scarney
I think this link should work. The other link was the link from the video section of my account.
Steve
Replied by scarney on topic 2003 Hyundai Elantra Timing Belt Walking
Steve
- scarney
8 years 11 months ago #14698
by scarney
Replied by scarney on topic Re:2003 Hyundai Elantra Timing Belt Walking
Hmmm, that's really interesting, also a relief. I've been trying forever to keep the belt on straight. I actually talked to another person today who said not to worry about it as well. Any other opinions from anyone else?
Steve
Steve
8 years 11 months ago #14712
Replied by Tyler on topic Re:2003 Hyundai Elantra Timing Belt Walking
I actually looked up the procedure on this belt the other day, and the tensioning procedure is very poorly written.
It mostly comes out to, "Turn the tensioner 'till it's tight." This is why I like hydraulic tensioners. :lol:
- EricGoodrich
- Thank you received: 49
8 years 11 months ago #14718
by EricGoodrich
Replied by EricGoodrich on topic Re:2003 Hyundai Elantra Timing Belt Walking
It's good that you're being thorough and questioning something that doesn't look right to you. That's a good habit to keep. The tracking of that belt looks fine to me. If you've ever seen an engine running without toning covers you'd see that the belt can track all over the place. but, If the belt stays anywhere on the pulley put that thing back together and start the engine. I've seen belts ride on the inside and I've seen belts ride on the outside. As long as it's not hanging off or rubbing on the timing covers it'll be fine. The only time I've seen a tracking problem is when there have been bad bearings. For example, a water pump bearing went once and when I took the covers off half the belt was missing and there was a ton of black rubber powder in the covers. From what I see in your video, it looks just fine. Coming from someone who has done hundreds of timing belts.
- scarney
8 years 10 months ago #15395
by scarney
Thanks to everyone for their input. Where I am ending up on this is if the belt is completely on the sprocket, but not perfectly centered, it's not a problem. I've put the belt back on now and haven't any problems in the short time I've driven the car.
