1986 Grand marquis start problems
  • jonee140
  • jonee140's Avatar Topic Author
8 years 11 months ago #14405 by jonee140
1986 Grand marquis start problems was created by jonee140
i have a 1986 mercury grand marquis and its having problems starting up. when i try to turn it over once it starts for 2 sec then sounds like metal clanking then dies when i try it again it doesnt to anything i need help
8 years 11 months ago #14425 by Doc n2mx
Replied by Doc n2mx on topic 1986 Grand marquis start problems
Hi,
The first thing you should do is turn the crank by hand, useing a beaker bar 2 or 3 times make sure nothing binds. If it does .. It may also be the starter you might have to remove it. I would also remove any belts I have seen ac pumps keep a motor from turning over. If you hear noise see if you can find it may be the flex plate or a shield (I hope).
Now if the motor will not rotate 2 or 3 times.
The motor needs to come out.
Start from there….
Good luck.
Doc
  • jonee140
8 years 11 months ago #14431 by jonee140
Replied by jonee140 on topic 1986 Grand marquis start problems
thanks for replying its strange because prior to the problem it ran like a champ and i just replaced the starter am i able to remove the belts and would it still run? or try to cut a/c for example out only
8 years 11 months ago - 8 years 11 months ago #14526 by Noah
Replied by Noah on topic 1986 Grand marquis start problems
You can start it without the belt to make sure it isn't an accessory pulley thats binding up the engine. Just don't run it like that for more than a minute or two.
While you've got the belt off, try turning each pulley by hand to see if you can find anything that's stuck.
I'd pull the engine oil dipstick and look for signs of metal debris. Glittery, shiny specks would be a bad thing
Any way something fell in the bell housing while you had the starter out? A bolt or socket or something?
For what it's worth, those old 5.0s were pretty mechanically sound engines. Hopefully it's nothing too serious
Last edit: 8 years 11 months ago by Noah.
