Chevy Malibu 2013 2.4L engine TPS voltage
  • karim
  • karim's Avatar Topic Author
8 years 11 months ago #14269 by karim
Dears,
I did TPS voltage test on Malibu 2013 2.4L engine. Max volt was 1.8v.
Does the tps voltage increase with releationship to wheel speed sensor? or My TPS should read 4-5Volt at wot in Park or Neutral Position?
I think that the TPS cant go over 1.8V if the vehicle is not moving (wheel speed sensor).
Any info highly appreciated.
8 years 11 months ago #14276 by Tyler
Replied by Tyler on topic Chevy Malibu 2013 2.4L engine TPS voltage
Hey karim! Moved this one to Repair.
I think you're right on about the TPS. Most drive-by-wire systems won't let you 'actually' snap the throttle wide open with the transmission in Park. :( No fun, right? Of course, the TPS should move full range if you go WOT in Drive.
