audi a6 2.7tdi starting issues
  • anuplazar
  • anuplazar's Avatar Topic Author
8 years 11 months ago #14267 by anuplazar
audi a6 2.7tdi starting issues was created by anuplazar
I need your help with an audi a6 2.7tdi.the issue is like when you switch to ignition the glow plug light will stay on and the engine wont crank.but if i try switching the key to ignition to on and off couple of times the glow plug light goes off and it starts perfect! i got the codes read as no communication with the ecm.After i get the engine started there are no fault codes.pls help
Show less
REPLY
8 years 11 months ago #14279 by Tyler
Replied by Tyler on topic audi a6 2.7tdi starting issues
Hey anuplazar! For our info, what year is your A6?
At first glance, this kinda sounds like an ignition switch problem to me. What does the check engine light do while the vehicle isn't cranking? Before going too much deeper, I'd be tempted to wiggle the key or tap on the steering column while the no communication issue is taking place.
  • anuplazar
8 years 11 months ago #14285 by anuplazar
Replied by anuplazar on topic audi a6 2.7tdi starting issues
It’s 2011 model Audi A6 2.7tdi .The engine light comes on n goes off when I try to crank.only the glow plug light stays on .
8 years 11 months ago #14287 by steve
Replied by steve on topic audi a6 2.7tdi starting issues
See if your missing power or ground to the engine ECU when it won't communicate
