1999 dodge dakota 3.9 p0301
  • cheryl hartkorn
  • cheryl hartkorn's Avatar Topic Author
8 years 11 months ago #14236 by cheryl hartkorn
1999 dodge dakota 3.9 p0301 was created by cheryl hartkorn
working on a 99 dakota 3.9 with a misfire, not a dead misfire but kinda slight and can be felt.
i checked engine vacuum at the brake booster reads 19 inches and very solid not bouncing.
swapped spark plug with cylinder #2
performed injector balance test with a pulse tool all 3 injectors dropped from 44 psi down to 23-24
compression matches the cylinder next to it
sprayed intake with brake clean no change
checked spark from wire jumps 35kv nice blue spark
only thing kinda looks questionable is the distributor cap looks worn on the contacts
truk has 235,000 on it
8 years 11 months ago #14289 by Tyler
Replied by Tyler on topic 1999 dodge dakota 3.9 p0301
Perhaps check for an intake-to-crankcase leak? As in, in the valley where brake cleaner won't reach. Plug off the PCV system and check vacuum at the dipstick.
8 years 11 months ago #14312 by juergen.scholl
Replied by juergen.scholl on topic 1999 dodge dakota 3.9 p0301
Under which condition(s) does the misfire take place? Any clues from the freeze frame data? Is it speed/load related or more pronounced at no load /idle?
Time to create page: 0.251 seconds
