2000 Jeep 4.0. Multiple cylinder misfire
  • Tootalltocare
  • Tootalltocare's Avatar Topic Author
8 years 11 months ago #14103 by Tootalltocare
2000 Jeep 4.0. Multiple cylinder misfire was created by Tootalltocare
Need map sensor wave patterns .
8 years 11 months ago #14111 by EricGoodrich
Replied by EricGoodrich on topic 2000 Jeep 4.0. Multiple cylinder misfire
iatn subscription gives access to thousands of both good and bad waveforms. Also, when you buy a Picoscope you get a bunch of good and bad waveforms. Buying from autonerdz gets you even more. A quick Google search can give you information about how to test a map sensor and even show you what you'd expect to see in a waveform.
Generally a map sensor will run off a 5 volt reference with near 0v or 5v at 0in or 30in. Confirm power/ground circuits, confirm baro/map correlation koeo, confirm map signal by open/short, gradual sweep with intake pressure change. Map sensors don't necessarily have a consistent waveform, not compared to something like a crank sensor anyway.
The following user(s) said Thank You: Tootalltocare
8 years 11 months ago #14145 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2000 Jeep 4.0. Multiple cylinder misfire
Usually I find the best of way of checking MAP sensors is OBD2 live data, also if the map sensor is out it will show up first as a fuel trim DTC
