1995 Blazer Ignition Timing
  • BLEE
  • BLEE's Avatar Topic Author
8 years 11 months ago #14084 by BLEE
1995 Blazer Ignition Timing was created by BLEE
Working on a 1995 Chevy Blazer which is OBD II. The issue is the ignition advance at idle is anywhere from -10 degrees and varies very much to -30 degrees. Once I hit the gas the ignition timing should go advance, but it stays negative. I had a P0325 code (knock sensor) and fixed this issue, and no codes since than, but still negative timing. According to specs, at idle the timing should be 21 degrees positive. I even put a resistor in line to reduce the dc voltage to 1.3 volts on the knock sensor circuit and eliminate it and the ignition timing is still negative. Not sure what the issue is....
8 years 11 months ago #14097 by juergen.scholl
Replied by juergen.scholl on topic 1995 Blazer Ignition Timing
The ignition timing u report is scan data? Did you check the timing with a timing light? There is actually NO way the engine would would run with 30 degrees retarded timing.
Get this resistor out of the knock sensor circuit as some computers do want to see a specific voltage created by the sensor at a specific rpm. If this signal is inhibited/suppressed by the resistor the computermight evaluate the knock sensor/circuit as faulty.
  • BLEE
8 years 11 months ago #14227 by BLEE
Replied by BLEE on topic 1995 Blazer Ignition Timing
Yes the data was from a scan tool. I have not checked the timing with a timing light yet, but can. The knock sensor circuit is good to go. I had to put in a resistor to ensure the computer is reading the 1.3 volts DC. Even if I take this resistor out and just hook up the knock sensors, no codes are found for the knock sensor circuit, but had a P0300 (random misfire) code pop up.
