[FIXED] 01 Jeep Gr. Cherokee 4.0L - No coolant fan operation
  • autotech1
  • autotech1's Avatar Topic Author
9 years 6 days ago - 9 years 4 days ago #13813 by autotech1
Hello I have a 2001 Jeep Grand Cherokee 4.0L With a code P1491 Fan circuit. Has new fan ass'y, relays, coolant temp sensor and a newly replaced reman pcm from another shop.. Testing done : At fuse box B+ at 30 on both low speed & high speed relays & KOEO B+ on 86. Can place B+ on 87 and fan will operate. All circuits have been voltage drop B+ & Ground even temp sensor wires. With connectors at PCM unhook ground voltage drop pin 2 & pin 21 which go's to 85 on both relays shows good. Can also ground these two one at a time and fan operates. Why does this P1491 kept coming back when engine starts with ac on. Also w/o ac on fan wont come on with engine temp or default fan operation from pcm when unhook. Thanks Charlie
Last edit: 9 years 4 days ago by Tyler.
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 6 days ago #13820 by cheryl hartkorn
Replied by cheryl hartkorn on topic 01 Jeep Gr. Cherokee 4.0L - No coolant fan operation
do they come on with a bi directional scanner?? if they do then its an input issue. if not then its an output issue
  • autotech1
9 years 5 days ago #13858 by autotech1
Yes no bi-directional output to fan relays on pin 21 or 2 from reman PCM. After my testing I finally talk the shop owner into getting another reman PCM (that was hard because he just got the one I was testing with) The second reman fix the problem, so watch out on some of these reman computers on these Chrysler products, some may not have correct programming. Thanks for the replies...
  • cheryl hartkorn
9 years 5 days ago #13860 by cheryl hartkorn
glad its fixed. remans always have issues it seems like
