2004 Honda Accord 2.4l Upstream showing zero volts
  • kimo.clyde
  • kimo.clyde's Avatar Topic Author
1 year 10 months ago #70206 by kimo.clyde
2004 Accord 2.4l with about 250k on the odometer. In the past, I was getting one of those O2 sensor codes(can't remember which), but the code would come and go. I was able to pass the CA smog test(with no cel) , but figured I'd replace the upstream O2 sensor because of the mileage and because of the fact that when I'd look at the live data for O2 sensors, I'd get zero volts on the upstream, but about .6 volts on the downstream. Figured it couldn't hurt to replace it with a Denso unit. Well, I'm still getting zero volts on the upstream O2 sensor and my question is this: Is this normal? I thought they both had to show voltage especially when reaching normal operating temperature? If so, then I might start looking at the wiring harness for the sensor for "opens". Also, it has the original Catyltic converter. Thanks for any help.
1 year 10 months ago #70470 by bills4065
Have you confirmed if you need a narrow band or wide band sensor upstream?
  • kimo.clyde
1 year 10 months ago #70503 by kimo.clyde
I entered my vehicle's information and different websites listed the same Denso O2 sensor.
1 year 10 months ago #70993 by bills4065
I see what you mean- live data not showing on sensor 1. Can your scan tool tell you the voltage it is seeing on what looks like on your both graphs to be 2 switching narrow band sensors?
1 year 10 months ago - 1 year 10 months ago #71042 by Monde
According to Alldata, the front sensor is A/F and the rear, narrow band. If the front sensor reads 0v, I would expect the rear sensor to go richer as a result of the false lean condition in my opinion. Also, the sensor has a circuit that should not be ignored.
Last edit: 1 year 10 months ago by Monde.
1 year 10 months ago #71057 by bills4065
If this car is indeed a wideband sensor I would be looking for a current and lambda pid for the upstream sensor.
  • kimo.clyde
1 year 10 months ago #71135 by kimo.clyde
What do you mean by a circuit that should not be ignored?
  • kimo.clyde
1 year 10 months ago #71136 by kimo.clyde
Can you please clarify the last part of your reply?
1 year 10 months ago - 1 year 10 months ago #71139 by Monde
The sensor has a heater circuit with 1 power feed coming from the A/F sensor relay ( black wire) and a control from the pcm(black wire)  a signal wire (red) and a ground wire(red/yellow) coming from the ECM/PCM. You have to check all the wires for opens and shorts. Power, ground, control to the heater and input signal to the pcm as well as checking the connector for corrosion, pin fitment and so on.
The following user(s) said Thank You: kimo.clyde
  • kimo.clyde
1 year 10 months ago #71141 by kimo.clyde
I will check on these this weekend. Wiring looks great though. No visible sections where it could be rubbing or chaffing from what I can see. 🤔
  • kimo.clyde
1 year 10 months ago #71143 by kimo.clyde
I think we're good. If this isban A/F sensor, here's the latest scanner data. What do you think?
1 year 10 months ago #71144 by Monde
A perfect lamda is 1, but 0.992 should be within the acceptable range. As long as you don't get a code, I think you are okay.
  • kimo.clyde
1 year 10 months ago #71145 by kimo.clyde
It actually went to 1.0 shortly after and stayed there.
