2006 Trailblazer 4wd not engaging
- Tutti57
- Thank you received: 254
9 years 1 month ago #12832
by Tutti57
2006 Trailblazer 4wd not engaging was created by Tutti57
So it is the 4.2 and when you turn the switch from 2wd to any of the other options, the indicator light just blinks then goes back to 2wd. I can hear a solonoid or something click under the truck.
My scan tool has a drivetrain status pid that does not change from 2wd when I move the switch.
I have good 12v on the vehicle side of the 4wd actuator. I was getting varying resistance readings on the signal wire in that harness when changing the switch settings, so does that indicate that the switch itself is working?
I saw a tsb that has you look at a 36pin harness for bad pin connections but they look ok.
No dtcs.
What's my next step, take a look at the transfer case motor?
No dtcs.
- Dtnel
- Thank you received: 67
9 years 1 month ago #12900
by Dtnel
Replied by Dtnel on topic Re:2006 Trailblazer 4wd not engaging
You can run it by a transmission shop and most of them have a scan tool that can communicate with the transfer case shift motor which is the indicator of what you're describing as I've had the same issue on my 2004 Chevy Tahoe.
I was able to diagnose mine because I would occasionally get a service four wheel drive in the driver indicator display in the dash and when I hooked my scan tool up I was able to manipulate the shift motor and see that it wouldn't engage in two different modes.
You can remove the switch from the dash and then plug it back in and do the same at the shift motor on the side of the transfer case. I have a NP 246 transfer case and the motor is on the driver side with a black harness plug coming from it that is plugged up around the top side.
As I stated above though someone with the advanced scanner tool can easily actuate that motor and tell you what's going on most likely. I use the modis edge by snap-on my self and that's how I was able to diagnose it.
Sent from my SM-G955U using Tapatalk
- Tutti57
9 years 1 month ago #12902
by Tutti57
Replied by Tutti57 on topic Re:2006 Trailblazer 4wd not engaging
I have a lunch scanpad. Maybe it has the bi-directional control to activate that motor with the motor out.
- cheryl hartkorn
- Thank you received: 130
9 years 1 month ago #12905
by cheryl hartkorn
Replied by cheryl hartkorn on topic Re:2006 Trailblazer 4wd not engaging
id look in the history dtc's
- Dtnel
9 years 1 month ago #12910
by Dtnel
IF it has bidirectional control you should be able to activate it while it's in the vehicle as well.
Sometimes it could be the switch that controls it as well but normally it turns out to be the motor from what I've been told. Does the vehicle have a DIC where it would display a message? I knew mine was amiss when the dic showed a message of "service 4wd" . The bidirectional will allow you to see what position it's in if your tool allows that which should make troubleshooting easier.
- Dtnel
9 years 4 weeks ago #13086
by Dtnel
Any luck?
- Tutti57
9 years 4 weeks ago #13087
by Tutti57
Replied by Tutti57 on topic Re:RE: Re:2006 Trailblazer 4wd not engaging
I'm still waiting for the truck to come back. Probably in a week or two. I'll def check back in, thanks!Dtnel wrote: Any luck?
