Hyundai Santa fe brake warning light flickering
  • rmcw1873
  • rmcw1873's Avatar Topic Author
9 years 1 month ago - 9 years 1 month ago #12711 by rmcw1873
FIXED
Hi guys a customer left his 2003 Hyundai Santa fe in this evening.His complaint being the parking brake/brake fluid level light flickers when driving and sometimes when stationary.I checked the fluid level,unplugged the sensor and the same thing happened,unplugged the parking brake sensor tried it again and the same thing again,read online people saying alternators causing problems like this but usually the battery light flashes also.Would doing the diode test that Paul shows be a good test for this?What other tests would you all recommend?
Thanks again,Richard
Last edit: 9 years 1 month ago by rmcw1873. Reason: Fixed
9 years 1 month ago - 9 years 1 month ago #12712 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic Hyundai Santa fe brake warning light flickering
Is the lamp shared with the pad wear indicator ? Pad wear circuits are prone to cause similar issues.
The alternator diode pattern test is quick and easy so go ahead and do it.
Last edit: 9 years 1 month ago by Andy.MacFadyen.
  • rmcw1873
9 years 1 month ago #12713 by rmcw1873
Hi Andy thanks for replying,I'll find out for sure in the morning but I'm pretty sure this car hasn't wear indicators fitted to it. I did notice that when I applied the handbrake the light brightened up
  • cheryl hartkorn
  • cheryl hartkorn's Avatar
9 years 1 month ago #12722 by cheryl hartkorn
Replied by cheryl hartkorn on topic Hyundai Santa fe brake warning light flickering
www.revbase.com/BBBMotor/TSb/DownloadPdf?id=198864 this might help i dont know though for sure
The following user(s) said Thank You: rmcw1873
9 years 1 month ago - 9 years 1 month ago #12724 by Gjauto
Scan the abs module and post the codes here.
What size engine is it/ body badge (se, le), I'll look over the wiring for it.
Last edit: 9 years 1 month ago by Gjauto.
  • rmcw1873
9 years 1 month ago #12742 by rmcw1873
Hi the model is a 2003 Santa fe 2.0crdi sm d4ea
The abs had a code stored c1203 right front sensor
The engine has p1527 sensor supply voltage 2
It is now not flickering which dosnt help !!
9 years 1 month ago #12748 by Ben
Is the abs light on solid as well? Is it 03 or 07? Now that the light is not flickering does the parking brake still illuminate it brightly (verifying cluster solder integrity) I suspicion a short to ground between cluster and abs unit but could be on parking switch or fluid level switch as well. maybe someone will post the wiring diagram to better understand the circuit, I'm not at the shop today to look 1 up.
  • rmcw1873
9 years 1 month ago #12749 by rmcw1873
Hi sorry it's an 03 don't know where I got 07 at.No there is no problem with the abs light the customer says it came on once a while ago with him but never showed again.Also the handbrake/fluid warning light hasn't played up since I've been working today and is shining bright when applied as it should
  • rmcw1873
9 years 1 month ago #12756 by rmcw1873
Thanks for all your replies,the fix was simple enough the wire from the brake fluid reservoir goes up behind the a.c. pipe where a few wires insulation had rubbed through and shorted.I would have liked to have posted a photo of the area but couldn't seem to master the one I tried earlier of the diode test,I'll keep trying,thanks again
The following user(s) said Thank You: Gjauto
9 years 1 month ago #12757 by Ben
Good find !
Time to create page: 0.453 seconds
