[Fixed] 2006 Mercedes CLS55 AMG O2 Sensor Codes
  • John Clark
  • John Clark's Avatar Topic Author
9 years 1 month ago - 7 years 6 months ago #12474 by John Clark
2006 Mercedes CLS55 (C219) AMG Supercharged 5.5L V8. 120K miles.
I have three O2 sensor codes as read by my Autel DS708 on the OEM side:
P200C-1 G3/4 (Right O2 sensor, before TWC [KAT] Aging, correction variable exceeded: Delay time too long (P2096)
P200E-1 G3/6 (Right O2 sensor, after TWC [KAT]: Level is above applicable threshold (P1999)
P200E-2 G3/6 (Right O2 sensor, after TWC [KAT]: Level is below applicable threshold (P1999)
I have a subscription to AllDataDIY, as well as the factory Mercedes WIS, ASRA, and EPC software that someone gave me. Unfortunately, I don't have the diagnostic module or wiring diagram module for my Mercedes service software, but Alldata gives me the factory wiring diagrams.
According to what I could gather from AllData, these codes indicate a worn/slow downstream O2. Visual inspection revealed oil leaking from the rear main seal that filled the sheathing of the downstream O2 sensor on the right side. I replaced both upstream and downstream sensors with Bosch (OEM) sensors on the right side just to be sure but....the codes came back. Failure!
Mercedes is a bit greek to me but I figured O2 sensors are O2 sensors and this seemed pretty simple...until I didn't fix the problem with two new O2's. With 120K it doesn't hurt to have an O2 sensor refresh just to keep it running at peak but I need to fix the problem too.
Scan data indicated rich/lean cycling on the upstream sensor, though the signal stays full rich longer than it stays lean on the scan tool. It looks like /---\/---\/---\/---\ whereas the left side looked normal: /\/\/\/\/\. The downstream sensor stayed fairly steady but sometimes around 150mV and sometimes at 600mV or so and I am able to get reaction out of it with throttle snaps, etc.. The left side (the good side) upstream sensor cycles rich-lean evenly but don't recall what the downstream sensor was doing other than I recall not being concerned with cats so it was steady.
Does anyone here understand the fuel control strategy on these that could give me some direction? From what I can tell it does use the downstream sensors for Lambda control which is why I went ahead and replaced the downstream sensor. Alldata mentions that the P200E code can actually cause the P200C code. The one thing I did not do, and I'm kicking myself for it, was check for heater voltage at the sensors. I had no heater DTC's so I took the shortcut and didn't check to make sure heater voltage/current was getting all the way down to the sensors. In the test prerequisites one of the things the PCM has to see is "no fault with oxygen sensor heating" so that also made me think it wasn't a heater issue. Fault setting condition for the P200E is "With two-sensor control switched on, sensor status change must be detected after approx 190s." Fault setting condition for the P200C is "approx. +/-1.0s (+/-TV)." I haven't been able to figure out what "TV" means.
On the OBDII side, the code I have is P2096 Post Catalyst Fuel Trim Too Lean Bank 1. The OEM P200E codes don't seem to be setting a P1999 on the OBDII side as the OEM code description indicates.
I don't have the vehicle right now and not sure when I'll get it back (I'll get it back soon, though) but wondering if there are any Mercedes folks out there that can provide a little direction for me. My first check will be the heater circuits but wondering if there is anything else that can set these three codes.
Thanks,
John
Last edit: 7 years 6 months ago by John Clark.
  • John Clark
9 years 1 month ago #12598 by John Clark
Replied by John Clark on topic 2006 Mercedes CLS55 AMG O2 Sensor Codes
Bump
9 years 1 month ago #12600 by matt.white
Replied by matt.white on topic Re:2006 Mercedes CLS55 AMG O2 Sensor Codes
Barely ever touch mercs but I'll reply.
If you have no heater codes, I wouldn't sweat it. I think you'll find they'll be fine.
Did all 3 codes come back or just the codes for the rear 02's?
Did you notice or record what the fuel trims were like? Is there snapshot data you can access and see what the car was doing idling/hard acceleration etc when the codes set?
Sorry, not merc specific, but within reason it's all pretty similar.
Can you access obd2 data? Does this car support it? I'm not sure where you're located sorry.
  • John Clark
9 years 1 month ago - 9 years 1 month ago #12601 by John Clark
Replied by John Clark on topic Re:2006 Mercedes CLS55 AMG O2 Sensor Codes
Thanks for the reply, Matt.
I'm in the US...NC to be more specific. It's a US model vehicle. Yes, all three codes returned. I did look at fuel trim data and everything looked normal at idle and 2500-3000 RPM.
I recall there was snapshot data for the OEM codes but I need to look again. When I get the car back that's where I'm going first, of course. It does support OBDII data. When I looked in OBDII data the only code stored was P2096 Post Catalyst Fuel Trim System Too Lean Bank 1. According to the P200C OEM DTC description I figured that's due to the P200C code, though. The Alldata code descriptions list P2096 and P200C being the same thing and give the Aging O2 sensor code description. I think the Autel is incorrectly describing the OBDII code. When using the MB service info, troubleshooting the P200C code along with P200E codes, the service info says the cause is the downstream sensor and that the P200C code is due to the downstream sensor.
It's confusing due to the two sensor fuel control on this vehicle. From what I can gather, now realizing I made a bad call, the downstream sensor needs to cross the 450mV threshold every minute or so. I don't have the vehicle in order to view the data and see what it's doing. I'm trying to gather some info and knowledge before I get the vehicle back.
Below are the MB service info docs I'm working from which led me to the bad call of replacing the O2's. I suspected the downstream O2 but replaced both of them just to make sure but it didn't do any good. That's why my next step was going to be to connect the Vantage Pro to the heater circuit and make sure the ECM is duty cycling the heaters properly...which I should have done prior to replacing the O2's but live and learn, I guess.
Thanks,
John
File Attachment:
File Name: P200C.pdf
File Size:67 KB
File Attachment:
File Name: P200C_Flow.pdf
File Size:288 KB
File Attachment:
File Name: P200E.pdf
File Size:71 KB
File Attachment:
File Name: P200E_flow.pdf
File Size:187 KB
Last edit: 9 years 1 month ago by John Clark.
  • John Clark
9 years 1 month ago #12617 by John Clark
I also found this diagram that shows what the downstream sensor is supposed to be doing. It's a bit simplified but if I understand it correctly the ECM is looking for the downstream sensor to cross the 450mV threshold at least every 190 seconds. Since I'm getting P200E-1 and-2 that means I'm getting a signal above and below the threshold, just not often enough. So, if the O2's are not at fault what would cause the downstream sensor not to oscillate above and below within that 190s limit? The MB flow chart is the same for both P200E-1 and E-2 and the only possibilities they list are current consumption problem of the heater, signal cable problem, or an O2 sensor problem.
If the current consumption of the heater is not correct then the causes they list are Fuse 43, circuit 87 relay, engine, heater circuit wire issue or the O2 sensor. I checked the info for the left side sensors and they use the same fuse 43 and circuit 87 relay so I suspect there's not a problem there since I'm not getting codes for the other side. So, I'm left with either a signal wire issue or heater circuit issue. I'm just wondering if there is something else I'm missing that the MB documentation doesn't discuss that can cause these codes...
File Attachment:
File Name: CATMonitoring.pdf
File Size:76 KB
  • John Clark
9 years 1 week ago - 9 years 1 week ago #13815 by John Clark
I've got the vehicle back and have put the scope on the O2's. The MIL is off at the moment but the same codes are still stored. The downstream O2's seem to mirror each other so I didn't take any scope screen shots of them. However, the upstreams are significantly different. Bank 1 (bank with the codes) seems to cycle rich-lean much slower than bank 2.
Here is my 'known good' bank 2 upstream sensor at about 2500RPM:
Here is my bank 1 upstream sensor at about 2500RPM. As you can see it stays rich while the other bank drops lean and back to rich in the same time frame:
Not sure it's helpful but here is a screen shot of both banks at the same time at about 2500RPM:
So, what would cause the O2 to stay rich like that on bank 1 for longer than bank 2? Long term fuel trim on bank 1 at idle is about +4.8 and short term is around 0.0. If I run the RPM up to 2500 the long term stays around +4.8 and short term goes up to around +7-10%, indicating to me a slight lean condition on bank 1 at higher RPM's.
It doesn't appear to me to be a vacuum leak. What would cause a slight lean condition on one bank and not the other that gets worse with higher RPM? The two items Paul always talks about are MAF and fuel delivery. There is no MAF that I can find. Could it be a dirty fuel injector? It is supercharged and I cannot find a MAF on this engine. Does anyone have any thoughts?
Last edit: 9 years 1 week ago by John Clark.
9 years 1 week ago #13818 by Andy.MacFadyen
Replied by Andy.MacFadyen on topic 2006 Mercedes CLS55 AMG O2 Sensor Codes
The two upstream sensors B1S1 and B2S1 control the fueling the downstream sensor are there to monitor that the catalyst is cleaning up the exhaust.
Even on a vehicle that has never had problem O2 sensors age and slow down and can drift out of calibration due to deposits and wear and tear and deposits on the internals of the sensor. An O2 is a tiny fuel cell which has a tiny internal catalyst on the surface of which a chemical reaction takes place. The other problem that can occur is the electric heating element or its supply circuit can fail this normally causes the sensor to take several minutes and higher RPM to start working.
After the engine is started from an O2 sensor has to warm up to come alive, when the engine reaches working temperature the ECU monitors the number of times the upstream O2 sensor signal crosses through 0.5v in a given time if after X minutes the crossing counts have not exceeded the required number the ECU flags up a fault code.
A sensor that has covered 100,000 miles will generally be serviceable have slowed down a little and the peak and minimum voltages won't cover as wide a range.
  • John Clark
9 years 1 week ago #13819 by John Clark
Andy.MacFadyen wrote: The two upstream sensors B1S1 and B2S1 control the fueling the downstream sensor are there to monitor that the catalyst is cleaning up the exhaust.
All that is why I originally replaced all four sensors. The codes came back after less than a week. This vehicle has four brand new OE Bosch sensors installed. I haven't checked the actual heater circuits but I don't have any heater circuit codes, either.
  • John Clark
9 years 1 week ago - 8 years 5 months ago #13821 by John Clark
Replied by John Clark on topic [FIXED] 2006 Mercedes CLS55 AMG O2 Sensor Codes
I just put the scope on the heater circuits and found them all pulsing normally at the O2 sensor connectors. I put the negative lead on a ground and found steady battery voltage on one side and PWM on the other side of each of the heaters. They are all getting power and the PCM is turning them all on and off normally.
Last edit: 8 years 5 months ago by John Clark.
  • John Clark
8 years 5 months ago #20452 by John Clark
I finally got the car back into the garage and the next step was going to be a smoke test of the exhaust. Didn't even need to go that far. A visual inspection of the exhaust revealed the front weld on the right hand converter is cracked all the way around. It's not even attached anymore. I'm sure it wasn't that bad before as I can't imagine I would have missed such an obvious defect.
What's interesting about this exhaust leak is there is no soot around the crack and the car is nice and quiet. It's obvious it's the problem, though, and am hoping someone can weld it for him as I don't have a welder.
I appreciate everyone's help here, though, and wanted to post the fix.
Thanks,
John
Time to create page: 0.396 seconds
