Map sensor ground issue
- Vtr1981
9 years 1 month ago #12174
by Vtr1981
Map sensor ground issue was created by Vtr1981
Have problem with map sensor reading,while checking wiring I have a 5 volt feed 2.9 volt sensor but on the ground I have negative0.1 volts why is it a negative reading any ideas thanks.
- Inge Jeppesen
- Ford master tech.
- Thank you received: 3
9 years 1 month ago #12178
by Inge Jeppesen
Replied by Inge Jeppesen on topic Map sensor ground issue
That means you are measuring 0,1 volts of potential between your leads, and if you switch your wires on your meter around it will show positive. It could also be some kind of galvanic voltage you are reading if there are different kinds of metal, gold for example.
Where do you have your ground lead when measuring?
9 years 1 month ago - 9 years 1 month ago #12179
Replied by Andy.MacFadyen on topic Map sensor ground issue
Probably just noise, especially if you checked it with the engine running. Ground voltages can vary depending on where you measure between, for example measure the difference between battery negative post and the block with the engine running.
Last edit: 9 years 1 month ago by Andy.MacFadyen.
- Vtr1981
9 years 1 month ago #12180
by Vtr1981
Replied by Vtr1981 on topic Map sensor ground issue
Battery negative and sensor ground
- Vtr1981
9 years 1 month ago #12181
by Vtr1981
It is very noisy signal on scope,I'll check block ground tomorrow thanks
- cheryl hartkorn
- Thank you received: 130
9 years 1 month ago #12186
by cheryl hartkorn
Replied by cheryl hartkorn on topic Map sensor ground issue
does the ground light a test light??
- Vtr1981
9 years 1 month ago #12203
by Vtr1981
Yeah when on battery positive
