P303 circuit malfunction..cylinder misfire
- Ken
9 years 2 months ago #12024
by Ken
P303 circuit malfunction..cylinder misfire was created by Ken
1997 jeep grand cherokee 5.2litre..Changed #3 injector, spark plug, and wires. Upon disconnecting plug from injector I noticed bare wires from connector plug touching just behind connector plug. Separated wires and taped and proceeded to change injector. Code still present. Please help. Thanks
9 years 2 months ago #12032
Replied by Andy.MacFadyen on topic P303 circuit malfunction..cylinder misfire
Hi Ken Welcome
I am going to move your question into the Repairs Question section where it will attract more replies.
9 years 2 months ago #12033
First question is it a constant dead cylinder misfire at idle or do you feel under heavy or light acceleration?
With a constant misfire the first check is check for spark and injector pulse on that cylinder.
You can use a normal tungsten bulb test to test for spark and injector pulse on that cylinder
- Ken
9 years 1 month ago #12063
by Ken
Replied by Ken on topic P303 circuit malfunction..cylinder misfire
More testing this evening reveals Open circuit #3 cylinder. multimeter reads 12.7-13+ volts on one wire and 0 on other wire while engine running as did test on #1 injector. Notice engine change when unplugging each injector on that side except for #3. My pcm has three connector plugs and I'm lost as to which pins are for #3
9 years 1 month ago - 9 years 1 month ago #12069
I don't know these engines but the first step is identify the colours of all the injector control wires -- if the injector wiring harness plugs into the main wiring harness check for continuity and control on the no3 injector control wire at this point. Then do the same at the engine computer
Normally on most vehicles the injector control wires are located right next to each other on the engine computer plug.
Be aware the wire can change colour at the connector between the engine harness and the main loom.
See this thread by Tyler for where to obtain an wiring diagram.
Last edit: 9 years 1 month ago by Andy.MacFadyen.
