2017 Mazda Cx-5 FTP sensor
  • johnddawson
  • johnddawson's Avatar Topic Author
1 year 10 months ago #67923 by johnddawson
2017 Mazda Cx-5 FTP sensor was created by johnddawson
I have a 2017 Mazda CX-5. The ftp sensor has 2.6 volts output at the sensor but the scan tool shows 0 volts. I am getting a p0452 code. I’m using an Otofix d1 lite scan tool. Where should I look next? I can’t find any wiring diagram on google.
1 year 10 months ago #67925 by Monde
Replied by Monde on topic 2017 Mazda Cx-5 FTP sensor
There are only two possibilities: the engine control module is not logical or there is an open in the wire causing the signal not to make it to the PCM. The latter is the most possible. Hopefully, you will get a wiring diagram that can help with the issue.
The following user(s) said Thank You: ferris48
  • johnddawson
1 year 10 months ago #67936 by johnddawson
Replied by johnddawson on topic 2017 Mazda Cx-5 FTP sensor
Does anyone have access to a wiring diagram to verify the PCM pin connection to the Fuel Tank Pressure Sensor? I think it goes to pin 2Y. Is that correct?
1 year 10 months ago #67939 by ferris48
Replied by ferris48 on topic 2017 Mazda Cx-5 FTP sensor
2AJ with coolant control valve, 2Y for without coolant control valve and there are 2 connectors from sensor to PCM. See attachments.
The following user(s) said Thank You: Lupe, johnddawson
  • johnddawson
1 year 10 months ago #68012 by johnddawson
Thanks for the diagram but the wire colors don’t match. There was no gray wire . The brown wire was the only color correct. Do you have any other diagrams for 2017 Mazda CX-5 2.5 engine py?
1 year 10 months ago #68016 by ferris48
See attachment for redrawn color diagrams unfortunately that's all I have to offer.
  • johnddawson
1 year 10 months ago #68017 by johnddawson
Thanks for the diagram but the colors don’t seem to be correct.
