2014 Jeep Grand Cherokee 3.6L P0305
- brianmstoltzfus
- Thank you received: 4
1 year 11 months ago #67647
by brianmstoltzfus
2014 Jeep Grand Cherokee 3.6L P0305 was created by brianmstoltzfus
Hi I have this 2014 Jeep Grand Cherokee 3.6L setting P0305 code on cold starts according to freeze frame. It is very difficult to duplicate as we have started it numerous times cold and always runs fine. What is a good way to navigate this diag. Spark plugs and coil have been replaced, same problem.
- juergen.scholl
- Active partschanger
- Thank you received: 462
1 year 11 months ago #67653
by juergen.scholl
Replied by juergen.scholl on topic 2014 Jeep Grand Cherokee 3.6L P0305
You may pressurize the cooling system and check for leakage in $5.
- brianmstoltzfus
1 year 10 months ago #67666
by brianmstoltzfus
Replied by brianmstoltzfus on topic 2014 Jeep Grand Cherokee 3.6L P0305
I should have mentioned, I have done this test. Also there has been no coolant loss.
- Thank you received: 1138
1 year 10 months ago #67681
Replied by Noah on topic 2014 Jeep Grand Cherokee 3.6L P0305
My first thought was also coolant leaking into the cylinder.
Because it's a cold start misfire, I feel like this test would be most effective performed before the engine is started with a camera in the cylinder.
- brianmstoltzfus
1 year 10 months ago #67683
by brianmstoltzfus
Thanks for this input. I have already performed this test exactly after the engine set overnight. Not seeing any coolant in the cylinder at all.
1 year 10 months ago #67685
Ok, thank you for clarifying
- brianmstoltzfus
1 year 10 months ago #73779
by brianmstoltzfus
I have finally removed bank 1 cyl head cover and found one of the intake cam lobes on cyl 5 is completely worn off. Interestingly cyl 5 had slightly higher compression that rest, 170 vs 150. The compression difference doesn't really make sense to me! But it needs repaired nontheless. Is it advisable to put a cam in this motor at 106k miles? With the cam damage as it is, obviously there is metal somewhere.
