1997 Honda Civic EX, 1.6L, 5 speed manual, no crank, no start.
  • Foxed Up Garage
  • Foxed Up Garage's Avatar Topic Author
1 year 11 months ago #67419 by Foxed Up Garage
Battery tested under load and is good, new starter, new ground wires, new ignition, clean terminals. When I turn the key, all I get is a single click at the solenoid. When I test with my multimeter I get full voltage at the solenoid. When I turn the key, voltage drops to 4 volts in the whole system, even at the battery. Checked with different battery, same thing. Tried jumping with a jump box and another vehicle with no change. I checked the clutch pads behind the pedal and both upper and lower are in good shape. I'm not sure where my issue could be from here.
1 year 11 months ago #67421 by Lupe
If you voltage drop on the starter wire and on the solenoids then you might have a locked up motor try turning it on the crankshaft manually
The following user(s) said Thank You: Noah, Tyler, Foxed Up Garage
  • Foxed Up Garage
1 year 11 months ago #67427 by Foxed Up Garage
Yeah, it’s cooked. Thank you for your reply. New engine it is.
1 year 11 months ago #67434 by Lupe
Thank you for getting back to us and good luck
