maf sensor
  • joe briano
  • joe briano's Avatar Topic Author
2 years 2 weeks ago #67092 by joe briano
maf sensor was created by joe briano
po 102 code maf sensor  circut low 2013 toyota venza 2.7 replaced checked single wire 1.8 to 4.9 snap throttle looks good but have permanent code still i think wire broke between sensor
and pcm worndering this because scanner shows data pid up and down and if wire is broken are these substituted values.
2 years 2 weeks ago #67120 by Noah
Replied by Noah on topic maf sensor
A permanent code and a current code are not the same thing.
A permanent code will not stop from passing a state inspection, and will not illuminate the check engine light.
You can fix a problem, clear the current codes, and a permanent code will remain until the computer is satisfied that the system is working as intended.
  • joe briano
2 years 2 weeks ago #67122 by joe briano
Replied by joe briano on topic maf sensor
thank you for that info very helpfull
