2010 dodge avenger 2.4
- fl0302..
9 years 2 months ago #11435
by fl0302..
2010 dodge avenger 2.4 was created by fl0302..
vehicle has a po301.i checked for spark and it does.my other issue is the engine light starts flashing on and off .i know that's part of the symptons sometimes with a misfire. vehicle idles good in park and runs ok at low speeds.what worrys me is under load the engine starts bogging down .i know with the the issue with the misfire the cat might be damaged.but i do not have a scope and have little rescoures.i tryed swaping coils and spark plugs.any help would be great
the fan
the fan
9 years 2 months ago #11436
Replied by Tyler on topic 2010 dodge avenger 2.4
Hey fl0302! Just to be clear, have you cleared codes and rechecked for new ones after swapping coils and plugs? The symptom of misfire under load definitely sounds like an ignition issue, so I just want to make certain that the issue hasn't moved since you did the swapnostics.
IMO, the next easiest step would be a relative compression test. No scope or test equipment required, just put the gas pedal to the floor and crank the engine to enable clear flood mode. Listen to the way the engine cranks and note any skips in the cranking cadence. There's a newer ScannerDanner video out that covers this very topic:
If you want to stay on the swapnostics track, then I'd suggest moving the fuel injector next. The fuel rail is easily accessible on this engine, and wouldn't be too hard to move the #1 injector to another cylinder. Clear the codes and recheck after a test drive.
The following user(s) said Thank You: fl0302..
- Ben
- Thank you received: 215
9 years 2 months ago #11438
by Ben
Replied by Ben on topic Re:2010 dodge avenger 2.4
Did you clear the codes and run another drive cycle since swapping the plug and coil to see if the misfire moved with it? I assume you only have a code reader and not a scan tool capable of live data?
- fl0302..
9 years 2 months ago #11439
by fl0302..
Replied by fl0302.. on topic 2010 dodge avenger 2.4
I will try preforming another drive cycle as you suggested.
Thanks again from both of you
The fan
The fan
Time to create page: 0.479 seconds
