2006 Chevrolet Silverado PO171 PO174
  • tlafontaine1111
  • tlafontaine1111's Avatar Topic Author
2 years 1 month ago #66934 by tlafontaine1111
2006 Chevrolet Silverado PO171 PO174 was created by tlafontaine1111
I am currently stumped on a Silverado that has a PO171 PO174. I have smoked the intake and found no leaks. New intake gaskets were installed, new bank 1 and bank 2 sensor 1 o2 sensors and new bank 1 sensor 2 o2 sensor which was replaced due to eaten wires by rats. Truck has also had maf replaced with aftermarket that I replaced back with factory due to being a bad reman maf. Will crank and run but after about 15-20 seconds the short term fuel trim will show around 50 while the long term is at 25 and stays there. Fuel pressure is at 63 lbs at idle. Any guidance would be greatly appreciated.
2 years 1 month ago #66936 by Monde
Replied by Monde on topic 2006 Chevrolet Silverado PO171 PO174
Raise the RPM to 3000 and see if fuel trims get better or worse. You may also check the freeze frame data for clues.
Time to create page: 0.263 seconds
