2009 Dodge caliber signal voltage fixed 1.6
  • w002mia
  • w002mia's Avatar Topic Author
1 year 6 months ago - 1 year 6 months ago #66918 by w002mia
Hey guys!
The upstream o2 signal wire is stuck at 2.5v whether it’s plugged or unplugged.
i read that it is supposed to be near 5v unplugged.
what are your thoughts ?
Last edit: 1 year 6 months ago by w002mia.
  • w002mia
1 year 6 months ago #66921 by w002mia
Replied by w002mia on topic 2009 Dodge caliber signal voltage fixed 2.5
So i was thinking maybe i need to buy a scanner and clear the codes to get the voltage to go back up.
  • Noah
  • Noah's Avatar
1 year 6 months ago - 1 year 6 months ago #66941 by Noah
Did you check the other oxygen sensor?
Are you talking about scan data or actual voltage measurements at the sensor connection?
Last edit: 1 year 6 months ago by Noah.
  • w002mia
1 year 6 months ago #66945 by w002mia
Both sensors read same voltage. I will check resistance of both heater elements and report back.
1 year 6 months ago - 1 year 6 months ago #66967 by Monde
The voltage that you are seeing may be a bias. According to the diagram that I am looking at, the ECM grounds the sensor and powers the heater control. Do you have good ground to the sensor and good feed to the heater from the  ECM?  Do you have good ground to the heater circuit?      Any codes?
Last edit: 1 year 6 months ago by Monde.
  • w002mia
1 year 5 months ago - 1 year 5 months ago #67243 by w002mia
Replied by w002mia on topic 2009 Dodge caliber signal voltage fixed 1.6
I measured the upstream o2 resistance and it was around 100 ohms so I changed it but still would like to see a 5v on signal wire when it’s unplugged. I mentioned it was 2.5 but actually it is 1.6v.
The return wire has 2.5v. I am trying very hard to find something because i don’t want it to be a bad ecu.
I am getting lean code p0171
Last edit: 1 year 5 months ago by w002mia.
