1995 Ford f-150 5.0 High idle along with rough idle
  • Lgaddie
  • Lgaddie's Avatar Topic Author
2 years 1 month ago - 2 years 1 month ago #66655 by Lgaddie
I have a 1995 Ford F-150 5.0 that has a brand-new engine that was just recently put in. I am experiencing high idle even when at operating temps and rough idling. Brand new plugs, wires, distributor, rotor, and cap, and has a new ICM and coil also. Brand new throttle body with the IAC and throttle position sensor. Could this be an ECM problem?
Last edit: 2 years 1 month ago by Lgaddie.
2 years 1 month ago #66666 by Chad
Do you have access to scan data? Is the Engine Coolant Temp reading, correctly? What are the values of fuel trim?
