p0449 on a 2007 GMC YUKON 5.3flex
- Woozybiffo420
I'll grab the wiring diagram when I get to a computer later today, but it sounds like you're describing a lack of power to the vent solenoid. Unfortunately, wiring problems are very common for these trucks, even when they don't live in the rust belt. :lol:
- Woozybiffo420
My next suggestion would be to connect a test light to B+ and touch on the control wire. If it lights, the either the control wire is shorted to ground, or the driver in the PCM is shorted to ground.
If it does not light, then there's still some kind of open circuit at the vent solenoid, possibly due to pin fitment or corrosion. Let us know what happens with the test light, and we can go further as needed.
- Woozybiffo420
Woozybiffo420 wrote: Alright finally had a chance to get under the yukon this weekend. I found that the plug that connects the after market harness to the actual solenoid was not plugged in all the way!!! (Thinking that would fix it) cleared the light started it, no light. Shut it down and started it again, boom p0449. So now I have power on both sides and no way to cycle the driver. I did the test you told me too and test light did not light, before the connector was plugged all the way in and after and neither wire has ground just power.
Thanks for the update!
Now that we've got a power feed, I think your next move is to recheck for voltage at the PCM itself. OR, there's another option:
It looks like C300 is a bulk connector that has the fuel tank pressure, the pump, the vent valve and the level sender in it. I don't know where C300 is, exactly, but it's the next easiest place to check if you can locate it.
If you can't find C300, or it's a pain to get to, just go direct to the PCM. Pin 61 of C1, a white wire with no wires to either side (according to the diagram, anyway). KOEO, there should be 12V. If you find 12V, then that would suggest a PCM problem. If you find less than 12V, that would suggest more wiring issues.
Let us know what you find, and we can figure out the next step.
- Woozybiffo420
Woozybiffo420 wrote: So I have .40 volts at the ECM/pcm white wire. I have 12.1ish at the red/white wire at the evap vent solenoid and 0volts on the control / white wire. If I have .4 volts at the computer, would that tell me the computer is the culprit?
The 12V reading on the red/white wire is definitely good, but I thought you had 12V on the white wire at the solenoid? :huh: Not trying to nitpick, just making sure I understand where you're at.
So, with the key on and everything plugged in, is this accurate?
I ask because the above is describing either a functional circuit, or an open vent solenoid.
- Woozybiffo420
Woozybiffo420 wrote: So I am a bone head and was testing while the solenoid was not plugged back in. I have 12v in 12v out and .4 at the ECM.
:lol: No worries! In that case, you're DEFINITELY looking at an open/high resistance in the control wire.
This is where finding where C300 comes in, as it'd enable you to split the circuit and reduce the amount of wiring you'd need to check. Otherwise, you're down to visual on the harness, or picking the control wire out of the harness and testing for voltage.
OR, if you just want the stupid thing fixed, run a new wire.
- Woozybiffo420
- Woozybiffo420
Oh well, we can still beat this! Let me know what voltage you find at the PCM when you have time?
- Woozybiffo420
- Woozybiffo420
Let me know what you find with the voltmeter.
