Fuel trim and fuel injectors
  • mike126
  • mike126's Avatar Topic Author
2 years 2 months ago #66344 by mike126
Fuel trim and fuel injectors was created by mike126
This message contains secure information
  • Away
2 years 2 months ago #66346 by Tyler
Replied by Tyler on topic Fuel trim and fuel injectors
Hey mike126! Welcome to the forums.
Do you have any fault codes or other symptoms to go along with your fuel trims? +11-15% isn't ideal, but not terrible, either.
Definitely post a screenshot of your injector ramps, if possible. For whatever it's worth, the injectors on the 3.5L/4.2L engines have historically been very reliable. Can't recall replacing one. Unlike in the shorted injector video, your Colorado uses sequential fuel injection, with each injector having its own driver. One shorted injector won't disrupt the function of the others in the same way.
Better fuel trims off idle would tend to suggest that fuel pressure is fine. If you wanted more confirmation, you could always check for power enrichment at wide open throttle. If you see the upstream O2 show full rich at wide open from a stop to the 1-2 shift point, then it's unlikely that you have a fuel delivery issues (pressure or injectors).
Off topic, but did you use the 'Private message' tab to create this thread? If so, just use the normal 'Message' tab in your reply. The private function may make your message invisible to other members, and makes it difficult to quote when replying to you.
  • mike126
2 years 1 month ago #66698 by mike126
Replied by mike126 on topic Fuel trim and fuel injectors
Only code is P0420. I found that exhaust manifold has hairline cracks. Cleaned area and put extreme heat jb weld. Did not fix fuel trims but did fix the issues of idle problem truck had after sitting overnight or for a long period. Sounded like truck had a racing cam. Now it sounds fine and normal. Do you know if timing chain slack affects fuel trims?
