Crank/cam correlation
  • Jamiecar
  • Jamiecar's Avatar Topic Author
2 years 2 months ago #66312 by Jamiecar
Crank/cam correlation was created by Jamiecar
I have a 2009 Buick LaCrosse with the V6 VVTI in it. It has a cam/crank correlation code. Im 99% sure it’s out of time but I would like to learn how to properly use an oscilloscope. It has a exhaust and intake camshaft sensor for both banks (4 in total). How would one go about testing with an oscilloscope? Does it matter what cam sensor I use, which bank I use? It also has two signals for the crank sensor.
2 years 2 months ago #66314 by Paul P.
Replied by Paul P. on topic Crank/cam correlation
What scope will you be using?
Aside from capturing the signal(s) and comparing it to a known good;
If you have a scope that can set a trigger on the crank signal, you can observe the CAM signal for variance.  With a Pico this is an easy task using the cursors.
Usually the PCM will set the code for 10 degree+ variance
Never stop Learning.
  • Jamiecar
2 years 2 months ago #66316 by Jamiecar
Replied by Jamiecar on topic Crank/cam correlation
I have access to a snap on triton scope, and an Autel scope. Would I need to capture both banks ( all 4 camshaft sensors) and the crank sensor to do a correlation test?
2 years 2 months ago #66326 by Paul P.
Here are some Bank 2 Known Good Correlations.
You must have a late model to have 4 Cam sensors, so under Service Info it's a 2010 model year.
This is the engine that is prone to the crank gear slipping on the Crankshaft because it is pressed on and not keyed.
Do you have codes for both banks?
Using a scan tool what are the timing variances?
This has a 30 tooth crank sprocket so 360 degrees divided by 30 gives us 12 degrees.
If memory serves me correctly the PCM will set correlation codes maybe 10 degrees plus.
The following user(s) said Thank You: Tyler, Jamiecar
  • Jamiecar
2 years 2 months ago #66327 by Jamiecar
P0017
Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor B
P0016
Crankshaft Position - Camshaft Position Correlation Bank 1 Sensor A
P0014
"'B" Camshaft Position - Timing Over-Advanced or System Performance Bank 1
These are the codes I have, it idles a little rough and with these codes I’m sure it’s out of time but I am new to using an oscilloscope and wanted to learn how to confirm it is out of time by using one
2 years 2 months ago #66328 by Paul P.
I'm sure Paul Danner did a timing video, but here is Ivan at Pine Hollow Auto Diagnostics;
Here is another;
Here are better known goods for both Banks;
Bank 1
Bank2
