No spark Cranks ok Chevrolet 4.3 2000
  • Janmisdag
  • Janmisdag's Avatar Topic Author
2 years 3 months ago - 2 years 3 months ago #65986 by Janmisdag
No spark Cranks ok Chevrolet 4.3 2000 was created by Janmisdag
Hello dear people
I have a very difficult problem with the Chevy 4.3 model year
My engine runs normally, but unfortunately I have no spark on all cylinders. I changed the wiring harness and installed a used ignition module. Unfortunately still nothing.
What I only noticed is when the engine control unit is plugged in, I have engine ground in the fuse box in the lines and fuses that are responsible for the ignition module and I also have ground in the pink line when the engine stops completely as soon as I turn on the ignition it then switches on plus current at the pink line.
please help, dear, thank you.
Can you check such an ignition module when it is removed? If so, please can you help me on how to check something like this.
Kind regards, Jan
Last edit: 2 years 3 months ago by Janmisdag.
2 years 3 months ago #65996 by Lupe
Replied by Lupe on topic No spark Cranks ok Chevrolet 4.3 2000
do you have any codes or do you have spark from your coil . i think those are known for bad ground wires ,check the front lower area of head and back
Time to create page: 0.437 seconds
