99 STS- Several cylinders missing with no codes!
- dyi4me
9 years 2 months ago #11284
by dyi4me
99 STS- Several cylinders missing with no codes! was created by dyi4me
My wife's 99 STS has surely tried my patience over the years! ....an understatement! I do have a few codes like an air inlet door movement fault and rear wheel sensor shorted, but nothing to point me to where to look as it almost seems to be in limp mode. It came and went a few weeks ago, but apparent it is here to stay this time. I chased a PO452 around for a day, until I realized it was an information only code, and causes no symptoms in performance. Fuel pressure is 45 -55 during operation, and the ignition control module tests as good. The number of cylinders affected seems to come and go.....up to speed at times with missing, and other times will hardly get out of its way! ....because the shifting is affected, my wife is set on it being a bad tranny, but think I have her convinced that engine problems is causing the shift problems.
As bad as it runs...I find it hard to believe that there is zero codes related....not even a misfire code. I need to research more to be sure if all or most of the pertinent sensor performance will show up as a code. My cousin has a shop with diagnostic equipment, but he seems to let his impressions of the problem, keep him from studying the data. I think he showed misfires that come and go, and mentioned something he thought wrong with spark advance. He was willing to bet on the ignition module, but had it checked last evening as good. Before I head back to his shop....anyone with any ideas? Jim
- Ben
- Thank you received: 215
9 years 2 months ago #11295
by Ben
Replied by Ben on topic Re:99 STS- Several cylinders missing with no codes!
What do you mean by misfires come and go? like sometimes it's missing sometimes it isn't? Sometimes worse than others? I would start with a spray bottle and a salt water solution and check the wires for arcing then check plugs , from what I understand of your explanation it sounds like a basic tune up . How many miles on car and when was last tune up?
- Ash03
- Thank you received: 6
9 years 2 months ago #11300
by Ash03
Replied by Ash03 on topic Re:99 STS- Several cylinders missing with no codes!
The vehicle should store intermittent misfire dtc's..
Since its intermittent on random cylinders, I would start by checking the 'main' stuff first.. Faulty coilpack, bad engine ground?
Very difficult for me to share an input with you guys, as I dont have the same vehicles in my country that you guys have.. So I have no idea what a STS is.. lol
Sent from my SM-G531H using Tapatalk
- dyi4me
9 years 2 months ago #11307
by dyi4me
Replied by dyi4me on topic Re:99 STS- Several cylinders missing with no codes!
Thanks for the replies. STS is an upgraded Cadillac Seville with the v8 DOHC 320HP Northstar aluminum engine. ....commonly known to "pop" the head bolts at the 100K mark!...DAMHIK!
update...no better with thorough cleaning of ignition module, but after cleaning two of the 4 grounds, along with several of the sensor connectors, it runs much better. Now I wish I had done one at a time, as one appears to be the culprit. I sprayed the ignition wires last night, and no noticeable arching ....more checking and inspection today!
