2008 Jeep Wrangler click, no crank.
  • joshadampierce
  • joshadampierce's Avatar Topic Author
2 years 4 months ago #65834 by joshadampierce
2008 Jeep Wrangler click, no crank. was created by joshadampierce
Hello,  I will get right to it.  I have a 2008 Jeep wrangler 3.8L.  The starter just clicks when you turn the key.  I replaced the starter in haste without much diagnosis due to the situation at the time.  No I am trying to figure this thing out.  It will start if you drop it in neutral, that would point to a possible neutral safety switch issue.  Got on shopkey and this Jeep doesn't really have one, it's internal to the transmission, but it's still kinda there.  Just not a tradition NSS.  Then upon further examination it still won't start sometimes in neutral, just clicks.  It is very random.  Temperature doesn't really seem to be a factor as it will do it cold or hot engine.  It never labors at all to start, battery in good condition.  Jeep either clicks or starts, that's it.  I haven't done any voltage measurements yet,  that's should've been my first step I know.  And that's what I'm going to do next, I'm just in the middle of building a house and all my tools are hour and a half away.  I just think it's  very weird it will start just fine, then the next will be a click.  I appreciate any help on the matter.
Josh
2 years 4 months ago #65836 by Noah
Replied by Noah on topic 2008 Jeep Wrangler click, no crank.
Is it definitely the starter that is clicking, and not the relay?
A couple things that come to mind for a starter that starts to work but won't turn the engine are weak battery, poor connection at the battery or starter terminals, or a poor block ground.
2 years 4 months ago #65838 by Kfuson92
Replied by Kfuson92 on topic 2008 Jeep Wrangler click, no crank.
I second bad connection somewhere.
Trace your battery cables, make sure the connections are clean, tight, and not full of corrosion.
You could verify this by running a set of jumper
Cables from the battery to the start when it wont start, but i feel pretty confident cleaning/repairing your battery cables and connections will take care of it
  • joshadampierce
2 years 4 months ago #65851 by joshadampierce
Replied by joshadampierce on topic 2008 Jeep Wrangler click, no crank.
Definitely the starter clicking. Doesn't try to turn over at all just a dead click from the solenoid. I will clean all the connections and check back thank you guys for your comments.
2 years 4 months ago #65854 by 70monte
Replied by 70monte on topic 2008 Jeep Wrangler click, no crank.
You should probably do a voltage drop test from the positive battery post to the post where the battery cable attaches to the starter, from battery positive post to the S wire post on the starter and from the negative battery post to the case of the starter.
  • joshadampierce
2 years 4 months ago #65856 by joshadampierce
I will do that also. I plan on working on it one day this week after work. Thank you guys I appreciate it.
