2012 ford transit no cooling fan speeds (underhood)
- cheryl hartkorn
- Thank you received: 130
Dunno about the cooling fan current draw... 30-ish amps at high speed would be my guess. But still, since the PCM controls the relays, I'm not sure that a fan draw problem would cause this. :huh: I don't suppose the fans come on with the A/C?
Not sure what the temperature the PCM has to see for the fans, but you've likely looked at that already. A pin tension issue on both pins is unlikely, as would both clamping resistors in the relays failing.
Please tell me this isn't the same Transit that you already replaced the computer for a downstream O2 issue! :lol:
- cheryl hartkorn
- cheryl hartkorn
cheryl hartkorn wrote: and to answer your question it is the same one!
:lol: This Transit has led a rough life! Or these newer Ford PCM's are just made of glass. :silly:
also forgot to mention fuse 16 and 17 were both blown.... so im going to do an amp clamp on it tomorrow while grounding the high speed fan pin at the pcm with a test light. the blades didnt feel tight or anything they spin with no resistance..
Ahhhhh now I understand why you wanted to measure the fans.
- cheryl hartkorn
- cheryl hartkorn
I have a love/hate relationship with TSB's - Good at explaining how to fix stuff, but never explains the WHY.
- cheryl hartkorn
Any more, I'm convinced that you Need two brands of scanners if you're using aftermarket equipment. No one brand 'does it all'. Just this week, I was working on a New Beetle with a lean code. I KNOW that VW uses idle and part load fuel trim values, but the Snappy wouldn't show them.
