Do you also replace the green signal wire when replacing a CKP?
- MitchM
Question :Do mechanics customarily replace the green signal wire when they install a new crank position sensor?
Schrödinger discusses fix of an intermittent CKP code P300 random cylinder misfire . chevy had just gotten a new crank position sensor to fix its P 300 random cylinder misfire. Car was still misfiring, especially at higher speeds when the engine was hot.
he fixed P300 s by replacing the green signal reference wire to the CKP. (NOT the ground wire or the yellow wire. )
HOW:
he started a back probe of the GREEN CKP signal wire. (which was not replaced when the new CKP was installed. )
he found the old green signal wire to the CKP " occasionally coming loose. " interrupting the signal.
Rx was to replace that CKP green signal wire w brand new. he also checked the other 2 CKP wires (yellow etc and they were good. )
he suggests to diagnose this problem w the wire use a lite or a scope running 2 channels "as the VOM won't fit. "
All advice welcome. how many hours, and how hard is it to replace the CKP green signal wire ?
- Thank you received: 1138
- MitchM
- MitchM
Can you reproduce the missfire by brake torquing the engine?
Do you have access to scan data? Some times a p0300 isn't as "random" as the code description would imply. If you can narrow it down to one bank, or even better one cylinder it would be a big step forward.
- MitchM
- MitchM
Maybe they did and found no problem? Or maybe they felt they had enough evidence to move on with repair? I don't like to take shots at other techs who don't have the chance to defend themselves, but if you think the signal wire integrity is compromised get under there and check it out. You can do it!why not check the integrity of the wiring to the ECM carrying the signals for CKP and CPS before a mechanic charges $300 for installing a new CKP ?
- MitchM
Please let us know if the p0300 comes back when you're done replacing the signal wire.
- MitchM
- MitchM
1/ did you read this entire thread from the 1st post I made suggesting that the integrity of the crank position signal wire may be at fault in causing the p0300? note that previous mechanics replaced the CkPS itself, not the green signal wire from it. since the CkPS replacement is done w engine 'cold' , and the green signal wire integrity degrades only after an hour of driving at highway speeds, the test of wire integrity 'cold ' will not disclose the problem. and replacement of CkPS 3x did not solve the recurring p0300 s.
2/ did you view the entire Schroedinger's box YouTube ? if so you'd know that no one is testing anything w a socket wrench. the Schrödinger's Box you tube video clearly shows and explains all the tools he used to run the test to find the fault in the Crank position sensor's green signal wire. his replacement of the green signal wire cured the P0300 random cylinder misfire.
I'm happy that your idea of changing the signal wire fixed your truck and I regret that I couldn't assist you, but it seems like you knew exactly what the problem was any way. Good work!
Actually, that's not at all how the video played out. If you pay attention, Matt was not diagnosing a p0300. This truck had codes that directly related to the CKP sensor circuit.2/ did you view the entire Schroedinger's box YouTube ? if so you'd know that no one is testing anything w a socket wrench. the Schrödinger's Box you tube video clearly shows and explains all the tools he used to run the test to find the fault in the Crank position sensor's green signal wire. his replacement of the green signal wire cured the P0300 random cylinder misfire.
I am impressed that this repair worked for you considering you have different trouble codes and symptoms.
