Injector issue ? 5.3 2013 Chevy Avalanche
  • rudnickif
  • rudnickif's Avatar Topic Author
2 years 5 months ago #65639 by rudnickif
So I am in a confused state. I have had a few P Codes and  I changed 02 Sensors and changed the Cats. I still have slight miss or a small ide issue. I thought that I would have Injector issues but I ohm them out and  I got the following reading I got 14.5 ohms on all injectors,; I am not convinced I have bad injectors. I have good voltage to O2's, The only thing that I have not done is smoke test. Could I have a bad fuel pump or could it be something else? Any ideas or where to look next ?
2 years 5 months ago #65645 by Chad
It would be helpful to know which P codes you had/have. It would, also, be helpful if you could describe the issue that you are having in more detail.
is not much to go on.  Why do you think that you have an injector problem?
What do you consider to be "good"? Are the upsteam sensors switching? What are the values of the downstream sensors? What do your fuel trims look like?
The more information that you can provide, the better the help that you will receive.
  • rudnickif
2 years 5 months ago #65649 by rudnickif
Replied by rudnickif on topic Injector issue ? 5.3 2013 Chevy Avalanche
So here are the codes I pulled today
P030 P059 P053 P059 P0135 P0155 P015B P015D
P219A
  • rudnickif
2 years 5 months ago #65658 by rudnickif
You can also see why I was thinking that would be a injector issue. I also checked coils and wires they are good
2 years 4 months ago #65661 by Chad
Actually, I can't. All of the codes that you have listed suggest an O2 heater issue.
  • rudnickif
2 years 4 months ago #65662 by rudnickif
just replaced about 2 months ago them all with AC Delco, I cheeked all voltages and grounds and i checked out good
  • rudnickif
2 years 4 months ago #65663 by rudnickif
also will this cause a rough idle and or a bouncy rpm
2 years 4 months ago #65664 by Chad
The forum can't help you if you don't answer the questions that are asked.
