(fixed) 97 toy tacoma 2.4L p0401
- gilbert
- Thank you received: 15
I have this 97 tacoma with a p0401 i apply vacuum to the egr truck stalls so egr is good. I also applied vacuum to the vsv valve and air was leaking slowly so i replaced it. The next day light back on same code this time i took the intake off cleaned all ports dirty but not plugged. At this time i also put a new vacuum modulator. The next day again light back on same code don't know what is next please help.
Thank you all for your help God bless.
- matt.white
- Thank you received: 29
- matt.white
- gilbert
Thank you Matt for your help today I tried a different scanner and I was able to activate the vsv valve. This means that the PCM driver are good. The R line does have good vacuum at the throttle body I also looked for leaks and found none. I did find a dirty PVC if that makes a difference.
- gilbert
Hey Tyler thank you for your help I just put a diagram of the EGR system hope this help.
- matt.white
With the VSV activated, do you get any vacuum at the EGR valve? These use some kind of goofy restrictor in the hose, so it won't be manifold vacuum. Around 8" would be good.
- gilbert
Hey brother i checked the egr valve for vacuum and it doesn't get any at any time. I checked the valve for vacuum at the Q line and activated the vsv valve and nothing. I T'ed from the Q and the vsv valve and activated the valve and nothing. Then straight too the egr valve and nothing the only line that has any vacuum is the R line.
- matt.white
- gilbert
Sorry I have not mentioned that it is a manual transmission no check valve. What if I T off the R line will that work?
Speaking of, another place to check is the hose coming off the exhaust, to the vacuum transducer. I've frequently seen carbon buildup in the pipe going to the vacuum transducer, which causes the transducer to never open. You can test for this by pulling the exhaust hose off the transducer and starting the engine, looking for exhaust flow.
- gilbert
Thank you brother I'll check on that and keep you posted.
- gilbert
The fix for this was blowing air through the p port on the throttle body. I had cleanded it with T/B cleaner until fluid came so i thought it was clean. I even poked it with a strand from a broom and it went through. That wasn't good enough to get enough vaccum so i blew it out with air and that took care of that. I drove the truck for three days and no check engine light thank you all for your help.
