Instrument cluster help please
  • Ash03
  • Ash03's Avatar Topic Author
9 years 3 months ago #11139 by Ash03
Instrument cluster help please was created by Ash03
Hey guys
Having some trouble with an instrument cluster (89 ford bantam), The fuel and coolant temp gauge does not work. Upon stripping up the cluster, I have found that the voltage regulator/stabilizer is blown (melted up). I cant see any numbers or specs on that regulator because its all melted up.
Does anybody know what voltage the gauges need inorder to work? I can get a new voltage regulator from my local radio service shop but they would need some sort of reference to work with (part numbers, etc).
I have tried google searching for info, but everybody has different voltages which is leaving me quite puzzled, some say 5.7v, some say 6v, some say 9v. The repair/workshop manual I have for this vehicle does not give any info on this.
Any help will be appreciated
Sent from my SM-G531H using Tapatalk
9 years 3 months ago #11140 by Ben
Replied by Ben on topic Re:Instrument cluster help please
Hey ash not familiar with that particular 1 but on the Ford mustang I've used the 5v regulator with great success . I would bet yours is the same
9 years 3 months ago #11143 by Ben
Also if your voltage is lower then it should be your gauge reading will be low if you raise engine temp to normal operating temp and your gauge is low you will know that your supply voltage is to low
  • Ash03
9 years 3 months ago #11145 by Ash03
Replied by Ash03 on topic Re:Instrument cluster help please
Ok thanks Ben.. I will buy a 5v first and try it out..
  • Ash03
9 years 3 months ago #11157 by Ash03
Update:
I went to the radio services shop, i got a 6v and a 9v regulator..
Fitted the 6v regulator on, grounded the guage - it only moves until halfway.
Fitted the 9v regulator on, the gauge moves until a little under the max mark.
With 12.02v the gauge goes a little above the max on both gauges (coolant temp and fuel)
Im guessing 11v will work out. Any suggestions?
The ground leg on the oem regulator was not connected (or maybe it was burnt out im not sure as theres no signs of a ground being connected) so I also noticed that with the ground disconnected on the regulator, theres a 300mV added to the regulated voltage (doesnt show a noticable different on the gauge though)
9 years 3 months ago #11158 by Ben
I think 9v is correct for this than I've never seen a 11v regulator on a cluster?
  • Ash03
9 years 3 months ago #11163 by Ash03
I dont know bud, a cluster is not my type of toy lol..
Also should i connect the ground leg to a ground or should i leave it out?
9 years 3 months ago #11165 by Ben
Yes connect your new voltage regulator ground
  • Ash03
9 years 3 months ago #11175 by Ash03
Ok cool i refitted the cluster.. I will start up the vehicle and test the coolant temp gauge tomorrow
  • Ash03
9 years 2 months ago #11297 by Ash03
Ok so I got everything hooked up, started up the vehicle and waited for it to get to operating temp +- 90degrees..
The fan kicks in, I then check the coolant temp gauge (was excited) it was at about just under quarter (maybe about 30degrees..)
Disappointed!
I will replace the sender switch and try again, Im kind of leaning against that right now (the vehicle was parked off for quite a long time and the oil sender switch is also not working)
If that does not work, Are there more options or should I just get another cluster?
9 years 2 months ago #11298 by Ben
Test your oil sending unit i believe this will be a single wire design on this car bot sure what spec is but if you check resistance to ground when engine off vs engine running there should be a difference there to tell you if the sending unit is working or not if sending unit is working try the input at the cluster to see if you have same signal there
  • Ash03
9 years 2 months ago #11301 by Ash03
I have already tested and replaced the oil sender, it was defective. Thats working fine now..
I will test the coolant temp sensor and replace if needed, when i have some time again.
Time to create page: 0.411 seconds
