Can history codes be removed from pcm
  • bizz2222
  • bizz2222's Avatar Topic Author
2 years 6 months ago #65178 by bizz2222
Can history codes be removed from pcm was created by bizz2222
Is there an easy way to clear history codes like timming chain repairs from the pcm so when the history codes are looked up they are gone after repairs
2 years 6 months ago #65179 by Tyler
Replied by Tyler on topic Can history codes be removed from pcm
History codes would get cleared during a normal code clear function. Permanent codes (Mode $0A) will only clear on their own after the problem is fixed, or if the ECM/PCM gets replaced.
The following user(s) said Thank You: bizz2222
Time to create page: 0.263 seconds
