FIXED! 1998 chevy k1500 5.7 vortec misfire
- Steven1980
- Hash Cash
- Thank you received: 3
- Sterline80
- Steven1980
First check- cold engine 55 PSI running - 20 min sit dropped to 41psi
second check-warm engine 55 Psi running - 20 min sit 52 PSI
third check- normal operating temp 55 psi running - 20 min sit 55psi, didn't drop
4th check- cold engine- 58psi running - 20 min sit 48psi
5th check warm engine - 55 psi running - 20 min sit 42 psi
6th check warm engine 56 psi running - 20 min sit 40psi
7th check normal operating temp 56 psi running - 20 min sit 41psi
Does this sound like a stuck open or closed poppet or the fuel pressure regulator?? Thanks again
- Steven1980
- Steven1980
- Steven1980
With fuel trims what is of interest in the total fuel trim for each bank so taking the first results bank 1 seems to have a total fuel trim of around +23% and B2 around +8%.
+23% is way above what is an acceptable fuel trim and indicates the computer is adding a huge ammount of fuel to counter a lean mixture.
It is a chicken and egg situation misfires make the exhaust oxygen sensor read lean but lean air fuel ratio causes misfires, however as you have eliminated most of the other causes of misfires it looks like lean air fuel ratio is the cause of your problem.
However before jumping to the most obvious conclusion it is Vortect injection poppet problem you I would look at output voltages from the 4 exhaust gad oxygen sensors. Get the engine fully warm at idle speed look at the voltage output from each upstream sensor B1S1 and B2S1. The voltage from both upstream sensors should constabtly jump up and down between roughly 0.1 volts and 0.8 volts, if your app graphs the readings this is the best way to check oxygen sensor activity.
If when the engine is warm the voltage from any of the oxygens sensors reads a constant 0.5 volts you have problem with the sensor or it's heater circuit. Try holding the rpm around 2,500 to 3,000 and look for any life signs from the sensors.
If the output from either B1S1 or B2S2 sensor is fixed low(below 0.5v ) try fluttering the throttle (just very very quick very small dabs on the throttle) this should drive the voltage towwards 0.9v indicating richer fueling.
You could try also disconnecting the Mass Air Flow sensor (MAF) to see if there is any improvement but I don't think this the problem
Also be aware the OEM airfilter and the condition of air tube is critical and can really upset the fueling on a MAF engne.
- Rolexservice
- Steven1980
- Steven1980
- skip
It was kind of a common thing back then.
- Thank you received: 1139
Come on man...Sterline80 wrote: Keep throwing parts at it. You're bound to fix it sooner or later.
You've never had to ask anyone for help before?
Keep it constructive or keep it to yourself.
- Tutti57
- Thank you received: 254
I'm suspecting a vacuum leak here since it appears to be impacting one bank. Fuel pressure wouldn't cause a one bank issue.
Set up the app to graph b1s1 voltage and stft B1 and stft B2. With a propane tank unlit, open the valve and "spray" the gas in suspecting areas like the intake manifold and hoses and when you find the spot the stft will instantly dive. The O2 will also instantly go rich and increase voltage due to them detecting the added fuel. The stft will be responding to that be decreasing the out of fuel it is being given.
You can also do Paul's favorite water trick around the intake when the engine is cold. I would focus on that bank that had the +25 trim though. That can cause misfires.
You can check to make sure the O2 sensors are repsonding by pulling a vacuum hose and watching to see if the voltage dives - low is lean. You can also introduce the propane to a hose or intake and see if they rise with the extra fuel. A full throttle run should show rich as well.
Keep at it!
The pro version of OBD Car Doctor is much more useable.
- Tutti57
- Steven1980
Sounds like you've been busy.
Glad it's back in action. Don't get down on yourself for not nailing it down right away. If it was easy, we wouldn't need forums like this or instructors like Paul.
Thanks for getting back to us with the fix.
- alaskabobb
