2014 Jeep GC Electrical problems -Intermittent CAN BUS errorcodes
- tomas
2 years 6 months ago - 2 years 6 months ago #65155
by tomas
2014 Jeep GC Electrical problems -Intermittent CAN BUS errorcodes was created by tomas
Hello!
New member here and hope you guys can help out
Im having intermittent electrical issues with my 2014 Jeep Grand Cherokee Overlander .
After some time while driving the radio reboots multiple times for 10-30 seconds and the blind spot system flashes on the instrument cluster at the same time.
After pulling codes i get a long list of CAN Bus codes, this is what i get:
BCM
U0011-00 CAN INTERIOR BUS OFF PERFORMANCE
U0147-00 LOST COMMUNICATION WITH TELEMATICS GATEWAY
U0010-00 CAN INTERIOR BUS
U0232-00 LOST COMMUNICATION WITH BLIND SPOT DETECTION MODULE
B181E-13 - HOOD AJAR INPUT-CIRCUIT OPEN
AIR SUSPENSION CONTROL MODULE
C212A-16 SYSTEM VOLTAGE-CIRCUIT VOLTAGE BELOW THRESHOLD
HVAC
U0184-00 LOST COMMUNICATION WITH RADIO
U0140-00 LOST COMMUNICATION WITH BODY CONTROL MODULE
U11B8-00 LOST COMMUNICATION WITH ICS (INTEGRATED CENTER STACK)
RADIO
AMPLIFIER
DRIVERS DOOR MODULE
PASSENGERS DOOR MODULE
U0164-00 LOST COMMUNICATION WITH HVAC CONTROL MODULE
MEMORY SEAT MODULE
U0016-00 CAN INTERIOR BUS (-) CIRCUIT LOW
HEATED SEAT MODULE
LEFT BLIND SPOT SENSOR
U0204-00 LOST COMMUNICATION WITH RIGHT FRONT DOOR MODULE
U11FA-00 LOST COMMUNICATION WITH RIGHT BLIND SPOT SENSOR
U0203-00 LOST COMMUNICATION WITH LEFT FRONT DOOR MODULE
INTRUSION TRANSCEIVER MODULE
EXTERNAL DISC MODULE
POWER LIFT GATE MODULE
The only active code is hood ajar and will replace the hood ajar switch/latch.
I have checked for water leaks on the BCM and everything is dry and looks good.
I have tested the battery and it’s good
I have with the engine started tried to trigger the error codes by wiggling the connectors/harness going to the BCM by the module, harness going to BCM from the ECU, Tapping the TIPM box and fuses, CAN distribution box under steering wheel.
No success
Any suggestions on to where to start troubleshooting?
Sorry for long text, dont know how to insert codes a better way.
BCM
HVAC
RADIO
AMPLIFIER
DRIVERS DOOR MODULE
MEMORY SEAT MODULE
HEATED SEAT MODULE
No success
Last edit: 2 years 6 months ago by tomas.
- Dyllanbro
2 years 3 weeks ago #66976
by Dyllanbro
Replied by Dyllanbro on topic 2014 Jeep GC Electrical problems -Intermittent CAN BUS errorcodes
Have you found out what was wrong? I am having the same problem.
- tomas
2 years 3 weeks ago #67063
by tomas
Replied by tomas on topic 2014 Jeep GC Electrical problems -Intermittent CAN BUS errorcodes
I had multiple damaged wires on main harness for rear bumper since it was resting on the exhaust.
So check all the cables under rear bumper or it might be any of the blind spot modules
